Interior trim won't go back in.
Old Feb 3, 2012 | 06:32 PM
89iroc89's Avatar
Car: 1991 firebird GTA
Engine: 305 tpi
Transmission: 5spd
Axle/Gears: 3.42 posi
I took off my headliner board and replaced the headliner, but now I can get everything in but the stupid trim that goes on top of the doors by your head and down the windshield beam! any stupid trick? Or maybe I broke them? Idk!
Old Feb 3, 2012 | 07:15 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Interior trim won't go back in.
Do you have the plastic pieces that hold them on? They can be bought at your local parts store.
If they are broke, take 1 with you to get the right ones.
Old Feb 3, 2012 | 07:47 PM
89iroc89's Avatar
Engine: 305 tpi
Transmission: 5spd
I mean i broke of the tabs on the actual piece. But I think it will still stick.. do they just slide in? Or?
Old Feb 3, 2012 | 08:39 PM
Car: '87 Camaro
IIRC,
Yes they slip about 1/2 to 3/4 inch.
Take a look at the underside of the trim piece. Look to see if it has a slot for the retainer to slip in.
Our t-top trim had a slot.
Gently push it on then gently down toward the dash pad.
It's been a couple years but we'll be doing it again in spring for cleaning & final assembly of our interior.
Old Feb 3, 2012 | 10:19 PM
89iroc89's Avatar
Engine: 305 tpi
Transmission: 5spd
Ok will try.
Old Feb 3, 2012 | 10:26 PM
89iroc89's Avatar
Engine: 305 tpi
Transmission: 5spd
what about the two plastic screw mabobbers?
Old Feb 4, 2012 | 09:30 PM
Car: '87 Camaro
Can you post a pic? I don't recall plastic screws. Maybe we need them for ours.
Old Feb 4, 2012 | 10:25 PM
89iroc89's Avatar
Engine: 305 tpi
Transmission: 5spd
Ok PO broke all the tabs and replaced them with screws. I got it all put back to gether!
1992 Trans Am
May 10, 2023 07:19 PM
lee01
Apr 9, 2016 01:56 PM
justin57
Aug 20, 2015 07:05 PM
BewleyBizzIROC
Aug 14, 2015 02:52 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
