Installed ABS headliner, but doesn't look quite right
Old Feb 5, 2012 | 05:44 PM
cdoyle's Avatar
Hey,
I just installed one of the fabric covered ABS headliners, but the fitment isn't all that great.
Because these aftermarket ones don't use the little plastic clips that the factory ones do. It sags in the front and it's really ticking me off, because I almost think it sags more than the old one I took out.
Is there anyway to fix this? Why don't these aftermarket ones have the clips there? The slots for them, are already in the car, so it seems dumb to not include them as part of the headliner.
If I push up on the headliner where those clips should be, the gap goes away and it actually look really good.
Any thoughts on how to make this better?
Old Feb 5, 2012 | 05:59 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Installed ABS headliner, but doesn't look quite right
Take the clips off of your old headliner and use windshield urethane to hold them in place on your new head liner..
Old Feb 5, 2012 | 06:09 PM
cdoyle's Avatar
my old ones were brittle and broke.
I've been searching, and looks like this is a common problem with these headliners, and some were able to fix it with HD velcro. So going to give this a try.
but ticks me off, that I have to now go get some velcro and hope it works.
Old Feb 5, 2012 | 08:03 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Use some thick pieces of stick on Velcro,it work really good.
Old Feb 5, 2012 | 10:59 PM
TTOP350's Avatar
Yeh, a lot of them are broke and no one knows it until they remove the headliner...
Old Feb 9, 2012 | 10:15 AM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
I used velcro and my headliner doesnt sag whatsoever in the front. Im not happy with the fitment around the t bar but thats another issue.
Old Feb 9, 2012 | 07:10 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
The velcro will hold for now, when the temp heats up so may the glue on the velcro that you stuck to the car. Time will tell.
As far as your t-bar fitment.
When the weather warms up take 2 1x4 boards, wrap them each in a towel.
Take the t-tops off. place the boards on either side of the headliner.
Take a rachet strap and tighten it up. one strap in the front and one strap in the back
NOT TOO TIGHT. Let it sit for the most part of the day.
The fit should be better afterwards.
Old Feb 9, 2012 | 07:35 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Thanks for the tip! Ill try that as soon as it warms up which in Seattle means July!!
Old Feb 9, 2012 | 08:04 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Is that the best replacement headliner out there? I need to do mine and would really like to know.
Old Feb 9, 2012 | 10:58 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Unfortunately, ABS liners are the only thing as far as aftermarket replacement goes.
Pillsbty10 and I tried the fiberglass headliner from Marks Custom Kits (does knight rider stuff and etc) and they were pathetic, at best.
Quality, finish, fitment, all substandard. To top the poor quality, returning them for a refund turned into an ordeal as well.
Pillsbry ordered an ABS from A1 (iirc) and it was satisfactory. Not nearly OEM fit but, it was not bad considering the alternative of no headliner at all.
Seeing it personally, I'd say for the standard DD, it's a decent piece. Certainly not OE/resto quality though.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
Golfvette
Aug 24, 2015 06:35 PM
TheJoeY88
Aug 13, 2015 06:51 PM
