1983 Speedometer woes
Old Feb 21, 2012 | 01:56 PM
devestator_x's Avatar
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
So, I was trying to diagnose a potentially bad bulb in my guage cluster and long drawn out story cut short... the dual needle on my speedometer broke. Only the KPH side, but it snapped right off. I pulled the needle off and tried to super glue the broken back, it was so brittle, the one peice crumbled into 4 pieces before the glue set.
The car only has 85,000 on it and I am only the 2nd owner, so I'd hate to swap out the speedo unless I can swap out the odometer assembly and keep that with the car.
What are my options here? I called Hawks and they have an entire 82-84 speedo, but not just a replacement needle. They also say the one they have is faded. Could I buy an 85 and up 85MPH speedo and swap the odometers?
Old Feb 21, 2012 | 02:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 1983 Speedometer woes
You can swap odometers to another 82-84 speedo, or an 85-89 speedo.
Old Feb 21, 2012 | 02:06 PM
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
Thanks for the quick reply. Another question.... Does jumping up to say a 115mph or 140mph speedo need re-gearing in the trans or anything, or is it pretty much plug and play (given that they are mechanical operation like mine of course)
Old Feb 21, 2012 | 02:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They're all directly interchangeable.
Old Feb 21, 2012 | 02:08 PM
Car: 2001 Camaro
Engine: 3800 Series
Axle/Gears: ??
Ok, thanks very much. I appreciate the info!
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
