Shifter boot clip
Old Mar 15, 2012 | 06:22 PM
Damon23's Avatar
Car: 1992 Z28
Transmission: 5 speed
Shifter boot clip
Can anyone point me to where I can get the clip to hold the boot of the shifter on a 5 speed up? Mine sags down and you can see the metal on the shifter. I want to make it right.
Thanks.
Old Mar 15, 2012 | 06:33 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Shifter boot clip
It's a small mound-shaped rubber piece that slips over the shifter and rests on the shifter's shoulder.
You might consider our site's classifieds.
EDIT (again): Often when the boot is removed, the rubber piece comes off the lever and drops into the cavity below. You might take a peek. If you're fortunate, it'll jump up and say hello.
JamesC
Old Mar 15, 2012 | 07:01 PM
Damon23's Avatar
Car: 1992 Z28
I had the console cover off and looked down in there and did'nt see it. I will check the ads. Do you or anyone have a picture of this piece and how it installs?
And how do you remove the shifter ****?
Old Mar 15, 2012 | 07:05 PM
JamesC's Avatar
Sorry, no pic. Install is simple: Remove the shifter **** and boot from shift lever. Slip the donut (really mound shaped) over the shift lever and push down until it rests on the lever's should (or small lip). Reverse procedure.
JamesC
Old Mar 15, 2012 | 08:53 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Unscrew counter-clockwise
Old Mar 15, 2012 | 08:57 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Pull the shift lever all the way back to 1st gear. Look at the very front of the shift **** just above the shift. You will see/feel a small slot. Use needle nosed pliers to reach in & grab the clip to pull it out.
Old Mar 15, 2012 | 09:07 PM
JamesC's Avatar
The T-5 **** simply unscrews. There is no clip.
JamesC
Old Mar 15, 2012 | 09:11 PM
Car: GTA
JamesC
Yeah. I was thinking Auto as most people wouldn't have had to ask how to untwist something & never looked to see what tranny he had.
Old Mar 16, 2012 | 06:58 AM
Damon23's Avatar
Car: 1992 Z28
Thanks guys. That was not easy. I see where that rubber piece was and I looked all around and it is gone. I'll find one. Now to find a better looking shifter ****. Mine is like most, leather worn on top.
Old Mar 21, 2012 | 09:10 PM
Dmans85's Avatar
Car: '85 Z28
Axle/Gears: 3.23 posi
I went a found some kind of rubber washer at the local hardware store, drilled it out a bit and pushed it on. Works like a charm and holds the boot tightly up to the top
Old Mar 23, 2012 | 10:11 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I used a zip tie instead of the rubber piece as I never had the ruber piece and its worked so far with no issues at keeping the boot up
Night rider327
Feb 25, 2016 09:50 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
