Hawks third gen t-top headliner fix??
Old Mar 21, 2012 | 08:51 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Hey guys I got me one of those interior kits from hawks third gen last year its a really good kit everything fits great its just that over the summer the front of the headliner was sagging in the front due to heat. Is there any way I can fix this sag and make it straight again?
Old Mar 21, 2012 | 09:11 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Hawks third gen t-top headliner fix??
Do you have a pic to see where it's sagging.
Old Mar 21, 2012 | 10:23 PM
82tarecaro's Avatar
I think others have used velcro.
Old Mar 21, 2012 | 10:32 PM
kitt23's Avatar
i know my friends sagged and put a screw in on each side where it was sagging ....he went screw method because hes doing knight rider conversion and itll be hidden anyways i plan to do same thing
Old Mar 21, 2012 | 10:33 PM
mantaguy's Avatar
Engine: 5.0 EFI
On my TA their was a piece of velcro factory installed when I replaced mine.
Old Mar 21, 2012 | 11:26 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
My bud had sagging and flapping issues with his t-top replacement headliner. We just got some GM knockoff interior trim screw with washers and drilled some carefully placed holes and screwed them in.
Placed 2 in the front header panel on each side of the center.
One midway on each side of the overhead light and one on each
side near the shoulder belt retractors and 2 more one on each side of the rear of the headliner near the trim piece.
Sure you can see them but again carefully spaced and placed so they look almost factory and not cobbled up.
Sure cured all the flexing and sagging issues.
Old Mar 22, 2012 | 07:53 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
for the money we have to pay for that head liner it should last a long time. I am almost tempted to just have the factory mold recovered if I am going to buy this and its going to sag in a year. thats totally unacceptable in my book
Old Mar 22, 2012 | 09:01 AM
82tarecaro's Avatar
Yep - it is junk. Recover your original if possible. You can make minor repairs to it with fiberglass.
Old Mar 22, 2012 | 09:12 AM
JWS's Avatar
JWS
If you do use velcro, use the heavy duty stuff. One of the problems i just starting having with my ABS headliner kit is that the speaker covers will come loose because the velcro that comes with the kit for the speaker covers is not heavy duty. eventually im going to pull the speaker covers off and redo them with HD velcro.
Old Apr 10, 2012 | 01:20 AM
thatsupnow's Avatar
here is a picture of where it is sagging it should be sitting a couple inches higher, Ive got a strip of heavy duty velcro that came with the interior kit but I think that it was meant for the rear speaker covers. What would be the best course of action? Drill and screw or go with the velcro. Thanks for the input guys
Attached Thumbnails Hawks third gen t-top headliner fix??-img_20120406_145120.jpg
Old Apr 10, 2012 | 07:45 AM
mantaguy's Avatar
Engine: 5.0 EFI
I would put a OH Console in,it would eliminate all of that.
Old Apr 10, 2012 | 07:17 PM
rushtk's Avatar
Car: Teal 92 Z28
Engine: 5.7
But will a OH console like that work in a camaro? Are they that similar? I will do that in a heart beat and mine is still good from factory.
Old Apr 10, 2012 | 07:26 PM
mantaguy's Avatar
Engine: 5.0 EFI
Sure,they are identical. just make sure when you get one,it comes with all the hardware to install it.
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
TheJoeY88
Aug 13, 2015 06:51 PM
ChevyZ71
Aug 13, 2015 07:30 AM
