Need help putting steering columm together
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Tighten up steering columm my ****!!!!
Wow it seemed so simple and it is if everything does not break and random parts fall off before you can even tell where they came from.
So far the damage is the headlight dimmer rod (guess I will do the floor dimmer mod now
) and for some reason my lock cylinder decided it wanted to break too, so its bypass vats and put a regular cylinder in it or get a new vats one.
Still do not know if the turn signals will work right
Anyway does anyone have good pics of putting it back together? Im up to the turn signal switch as of now and Im trying to figure out what my random parts that fell out without me seeing where they came from go.
Ill try to get up some pics of the random parts
) and for some reason my lock cylinder decided it wanted to break too, so its bypass vats and put a regular cylinder in it or get a new vats one.Still do not know if the turn signals will work right
Re: Need help putting steering columm together
random plug and wire
random clip thingy
random plastic something or another
what does the brass spring loaded thing do on the trun signal switch? to me it looks like it would get caught in the lock plate and break off
random clip thingy
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If you haven't seen it, the link below has plenty of pics/info:
https://www.thirdgen.org/forums/susp...-steering.html
JamesC
JamesC
Engine: 4++,350 & 305 CIs
well the parts your showing are
1 unsure but *looks* like the vats plug
2 its a clip that goes in with the plastic under your ign key cyl.
3 is a part that goes lower left of the colum and your bright light switch pushes on it
your going to have to take some stuff back apart to get it all back in.
You need to test each switch and part for proper operation as it goes back together.
If you haven't seen it, the link below as plenty of pics/info:
JamesC
JamesC
I think the plug is from my alarm
anyone know what that brass piece does on the turn swtich and how it does not get in the way of the lock plate
May help others
http://www.fieros.de/en/articles/steering.html
The brass locks the steering wheel from turning when you pull the key out. Just like you think.
The part for the brights should be put back in or your lever may flop around..
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Man I attempted the same thing,I had it done by a mechanic before I couldn't drive it there.
well I got it done
I need a new ignition cylinder tho, right now a 10MM socket is the key and a resistor is on the VATS wires.
I did away with the turn signal high beam and went to a old school floorboard switch.
Only thing that I could not get to work right was the lock for the steering wheel
Otherwise its great, got a little play in one of the ball bearings on the column. The one behind the turn signal cam and spring for the horn ring/lock plate.
anyone know where I can get one?
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
The brass thing is the contact for the horn switch (that makes contact with the white disc)... The column lock is up towards the top of the column and engages the lock ring.
If you've got play in the upper bearing still, that means you didn't seat the inner race (gold piece) all of the way and you've probably bent your lock plate. The race didn't seat (if you remembered to put it back in), the spring above it didn't seat, the signal cancel cam didn't seat, and your lock plate isn't working (and probably bent to crap, ask how I know
) because everything is out of place. Go back in and do it right before you end up in a crash.
) because everything is out of place. Go back in and do it right before you end up in a crash. Joined: Oct 2001
1992 Trans Am
May 10, 2023 07:19 PM
Fronzizzle
Mar 18, 2019 08:29 PM
backtothe80s
Sep 5, 2015 12:39 AM
