Delay wipers not working?
Old Mar 29, 2012 | 03:19 PM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Any idea where to start looking for the problem? Thanks!
Old Mar 29, 2012 | 06:54 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Delay wipers not working?
You need a new cover on the wiper motor.
Old Apr 5, 2012 | 01:29 PM
Engine: All 5.7's
I'll look at the cover later but any chance you could elaborate a little more? Thanks Brother!
Old Apr 5, 2012 | 03:00 PM
mantaguy's Avatar
Engine: 5.0 EFI
Sure, all the controls are in the cover,I had a problem with mine the intermittent wasn't working,so I checked the service manual and it says REPLACE COVER.I had the same problem as you did.All you do is take the cover screws off,remove cover and make sure you put the new one back in the same way.Good luck.
Old Apr 8, 2012 | 04:17 AM
Engine: All 5.7's
Thanks!
Old Apr 8, 2012 | 11:25 AM
cdoyle's Avatar
And just want to reinforce that you install it correctly, because if you don't. The first time you turn your wipers on, it will break the piece that moves inside there and you're back to looking for a new cover
Old Apr 8, 2012 | 06:51 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Are there no repro covers being made? Junkyard finds only?
Mine are bad but the only way of knowing if the used one is good or not, is to buy it & install it.
Old Apr 8, 2012 | 07:23 PM
mantaguy's Avatar
Engine: 5.0 EFI
I'm sure their still available,checkout some GM parts suppliers on the web.
Old Apr 11, 2012 | 08:40 PM
Engine: All 5.7's
I don't think they are available from GM anymore. Tried a few dealers and they did an inventory search and found none left. Any ideas?
Old Apr 11, 2012 | 09:02 PM
cdoyle's Avatar
wrecking yards are going to be your best bet.
What year and model are you looking for?
Old Apr 11, 2012 | 09:07 PM
mantaguy's Avatar
Engine: 5.0 EFI
I got mine from a junk yard,I guess I was lucky! this one works fine,Knock on Wood.If you can't find one,you can put a new motor in.I know their still available.
Old Apr 11, 2012 | 09:12 PM
cdoyle's Avatar
One thing you can check on yours is make sure the 2 contacts on the cover are touching the contacts on the motor.
I know if are not making contact the delay option will not work. That happened to me, one of the contacts on the cover broke. I had to come up with something to make the connectors touch again.
Old Apr 11, 2012 | 09:40 PM
mantaguy's Avatar
Engine: 5.0 EFI
http://www.amazon.com/gp/product/ima...1&s=automotive
Here you go I found some for you.
I'm sorry does't fit yours I'll look again
Old Apr 11, 2012 | 09:50 PM
mantaguy's Avatar
Engine: 5.0 EFI
Sorry about that,I goggled your wiper motor and that popped up.
Old Apr 11, 2012 | 10:24 PM
mantaguy's Avatar
Engine: 5.0 EFI
ACDELCO OE SERVICE 22127287 Windshield Wiper Motor
Windshield Washer Motor Cover Kit (VPI 1-877-846-8243)
Item condition: New
Compatibility: See compatible vehicles
US $17.64
Buy It NowBuy It Now
Add to cartAdd to cart
Add to Watch list
$10 back on 1st purchase & 6 months to pay
Subject to credit approval.See terms
Shipping: $8.95 - Standard Shipping
| See all details
Item location: Branford, Connecticut, United States
Ships to: United States See exclusions
Delivery:
Estimated between Fri. Apr. 13 and Thu. Apr. 19
Payments:
, Bill Me Later | See details
Returns:
30 days money back, buyer pays return shipping | Read details
Learn more
Share:
| Add to Watch list
Top-rated seller
coast2coastautoparts ( 161)
97.6% Positive feedback
Consistently receives highest buyers' ratings
Ships items quickly
Has earned a track record of excellent service
Save this seller
See other items
Visit store: Coast2CoastAutoParts
Ad Feedback|AdChoice IT STATES IT WILL FIT YOUR 89 CAMARO
Old Mar 25, 2014 | 07:32 PM
Engine: All 5.7's
Thanks Brother.
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
Fronzizzle
Aug 17, 2015 02:52 PM
dhonda200
Aug 11, 2015 11:50 PM
slade5612
Aug 11, 2015 07:19 PM
