Footwell wiring problem
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
Hello! I have an issue with my footwell lights not properly operating when you open the door, ive chased wires and i cannot find the wires that connect to the door jam switch. From the wiring systematics in haynes manual it says the door jam switch goes just before the actual footwell socket, but that wiring looks like it goes right back into the dash. I'm not sure how to wire this lol. I have an 84 firebird, original 2.8 v6 car, now a v8 swap, computer ripped out, harness for computer is still there.
Thanks for reading!
Thanks for reading!
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Footwell wiring problem
Double check bulb connection as well as fuse. With age and vibration they sometimes loosen up slightly.
Engine: 357
The light sockets work with headlight dimmer switch. Door jam switches have no wires hooked to them, and i see no stray wires hanging out.. lol
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Engine: 357
Ive been staring at that for a few days, can someone pop off their kick panel and take a pic of where the wire goes from the door jam switch? Just straight to the bulb socket? Idk where it splices in.
db057
Aug 11, 2015 10:11 PM
