Rivets on power window motor
Old Apr 8, 2012 | 02:39 PM
JLCustomizing's Avatar
Car: 1984 Trans Am
Engine: 5.7 Liter V8
Transmission: Auto 700R4
Axle/Gears: Stock
I'm getting ready to do the manual to power window conversion (if anyone has a really good thread for this let me know, I havent found any) and I was wondering when you put the rivets into the regulartors if a threaded 1/4"-20 rivet gun would work and if I need any other pieces to do the rivets. I have the rivets these(http://www.ebay.com/itm/370592502487...84.m1439.l2649) but to put these in dont I need another piece that those go into? All the 1/4" rivet guns that I see are threaded ends so it's confusing me some.
Old Apr 8, 2012 | 03:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Rivets on power window motor
they may have threaded ends so you can install adapters for the slammer 1/8 and 3/16 rivets, but thats all.,
Old Apr 8, 2012 | 04:55 PM
Car: 1984 Trans Am
Axle/Gears: Stock
So I should be fine with the threaded rivet gun? Says its 1/4"-20. I dont know why this confuses me but maybe im thinking about it to hard.
Old Apr 8, 2012 | 09:11 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I just put small 10mm bolts in place of the rivets with lock washers. Never had an issue ever
Old Apr 8, 2012 | 09:21 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
The rivet gun should look like this:
They are not threaded, it works just like a normal rivet gun - just bigger.
Adapters can be used with a smaller rivet, but the torque from the power window motor over time is not kind to them.
Do you have the factory wiring for these?
What are you going to do with the holes in the door panels left from the window cranks?
Are you going to cut the console for the switches, or do you have a different console?
It really isn't too hard to do.
If you have any questions - just ask?
Old Apr 8, 2012 | 10:22 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I just used a $9.99 rivet gun and the biggest cheap rivet that fit with a #4-6 washer for the back side to beef up the hole coverage. worked just as well as the fancy monster they want you to use.
Old Apr 9, 2012 | 10:45 PM
Axle/Gears: unknown
Sometimes the biggest cheap rivet that fits may not last the longest.
Sometimes.
I have always used this type of gun.
GM says to use this rivet, it requires this gun.
If GM could of gone cheaper, do you think they would of?
I have never had a problem.
I have seen doors with rounded out holes, because they used steel rivets or nuts and bolts.
It is actually worse on the 4th gens with the fiberglass/plastic doors.
I hope yours lasts
Old Apr 16, 2012 | 01:10 AM
tlandoe's Avatar
Car: 1983 camaro z28, 1981 honda cb650
Engine: Lu5 305 crossfire v8
Axle/Gears: 2.93
I say go with some bolts and lock washers. I did and guess what? the regulator spring fell out somehow and I have to take the regulator and motor out again and reinstall it! Glad I only bolted it in cuz if I had to go back and grind rivets off, I would be quite upset.
Bolts and lock washers are much more forgiving and chances are you already have the correct tools
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 13, 2015 12:59 PM
