Would it be easy to fix this?
Old May 2, 2012 | 01:07 PM
orangek's Avatar
So, Im looking at a new 3rd gen camaro, and in the picture the dash board is cracked. I wanted to know if I would be able to fix it, and how? Or if I do buy the car, would I need to get a whole new dashboard? Any tips are appreciated thanks.
Heres the picture:
Old May 2, 2012 | 01:20 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: Would it be easy to fix this?
Very common, and no, not an easy fix (assuming you want it to look and fit like stock).
Cheapest solution is usually to find a used one, assuming you can find one that isn't also cracked. I got lucky and scored one at the local pull-a-part a few years ago for around $20. But with these dash pads all being 20+years old now, there's no telling how long before a good used one cracks too.
Another option is to simply put a "cap" over it....this would be a very thin, molded plastic cover that looks similar to the original, and would be glued down on top of your existing dash. Most 3rd gen parts places probably stock these.
A carpeted dash mat/cover would be another inexpensive option, but not really a fix as it just hides your cracked dash.
I want to say someone reproduces dashes for our cars, but they're not cheap ($250+).
Removal of the dash pad is simple though, just take out the 7mm screws that are located in the defrost vents and underside of the dash top. Usually comes out in 5-10 minutes.
Old May 2, 2012 | 01:23 PM
orangek's Avatar
Wow I thought it would be a lot easier and cheaper then that. Thanks though, knowing that I'll try to use that as a reason to get the dealer to come down on the price.
Old May 2, 2012 | 01:34 PM
onthedownlow's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
I seen a member here use this over lay and it came out awesome! Here's a link to the cap.
http://www.rickscamaros.com/camaro-d...1984-1992.html
Old May 2, 2012 | 03:34 PM
orangek's Avatar
So with that i just put it over the current top of the dash? Or do I replace the whole top with that?
Old May 2, 2012 | 03:38 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Camaro Dash Pad Overlay, 1984-1992
Replacement Shell
Fits Over Existing Dash
Instantly Restores Dash To Factory New by Covering Unsightly Cracks
Covers Padded Areas of the Dash
Great Alternative To Expensive & Time Consuming Dash Restoration
Correct Dash Graining
Easy To Install
Supplied With Adhesive
Here's another choice:
https://www.thirdgen.org/forums/spon...lded-dash.html
JamesC
Old May 2, 2012 | 07:48 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I wouldn't bother trying to fix that!!! if you have the money to buy a new OER pad from Classic buy it,if you don't I would just buy the cover for it.They do look real good.this is a cover for the TA or FB.
I put this in temporarily until Classic has the OER dash pad in stock.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
92firebirdguy
Sep 1, 2016 07:53 AM
85 Jimmy
Sep 30, 2015 07:56 AM
