Dash Cracks
Old May 22, 2012 | 09:25 PM
Lt1Chris's Avatar
Car: 01 Acura TL
Engine: 3.2 Vtec
Transmission: 5 speed
Axle/Gears: ?
Dash Cracks
if i used bondo on my dash would it hold
Old May 22, 2012 | 09:33 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Re: Dash Cracks
Use fiberglass resin, then bodo, then sand it out. Then paint it.
Old May 22, 2012 | 10:02 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Dash Cracks
Don't waist your time and cash!!! buy a replacement.
Old May 22, 2012 | 10:04 PM
Car: 1992 RS 6spd
Re: Dash Cracks
While I agree, it's his car so I answered.
Old May 22, 2012 | 10:15 PM
Lt1Chris's Avatar
Car: 01 Acura TL
Engine: 3.2 Vtec
Axle/Gears: ?
Re: Dash Cracks
i have alot o free time right now and bondo and fiberglass just sitting inside the shop
Old May 22, 2012 | 10:29 PM
Car: 1992 RS 6spd
Re: Dash Cracks
Then I say go for it, and learn. And second, enjoy yourself.
Old May 22, 2012 | 11:27 PM
Lt1Chris's Avatar
Car: 01 Acura TL
Engine: 3.2 Vtec
Axle/Gears: ?
Re: Dash Cracks
ill down for it got to get extra sand paper
Old May 23, 2012 | 02:47 PM
mantaguy's Avatar
Engine: 5.0 EFI
Re: Dash Cracks
If your going to rebuild your dash,do it this way
It's the only one I've ever seen that came out very good.https://www.thirdgen.org/forums/inte...ulit-dash.html
Old May 23, 2012 | 03:05 PM
82tarecaro's Avatar
Re: Dash Cracks
If you are going to fill cracks on the dash don't use bondo. Use a plastic epoxy like Evercoat Maxim.
The problem is, you will lose the texture in the repaired area, and it will be obvious where the repair is. I tried this, and used SEM texture spray, and bedliner to hide a small repair I made, and was not happy with the results. Do yourself a favor and find a replacement. That is ultimately what you will do once you try to repair it and the repair is obvious.
Old May 23, 2012 | 03:09 PM
mantaguy's Avatar
Engine: 5.0 EFI
Re: Dash Cracks
Do yourself a favor and find a replacement. That is ultimately what you will do once you try to repair it and the repair is obvious.[/QUOTE]
Old May 23, 2012 | 08:42 PM
coconut88888's Avatar
Re: Dash Cracks
Has anyone tried these people http://justdashes.com/Products.htm ?
Their process seems to be just like the original.
Old May 23, 2012 | 10:17 PM
mantaguy's Avatar
Engine: 5.0 EFI
Re: Dash Cracks
From what I here,they are very expensive,their are a couple of threads talking about them maybe about a month or two ago.
tyeo098
Nov 30, 2015 06:27 PM
MantyZ28
Nov 8, 2015 06:54 PM
codeysabatini
Sep 20, 2015 11:36 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
Stryker412
Sep 7, 2015 09:11 AM
