5th Gen seats into a 3rd Gen Camaro
Old May 31, 2012 | 05:43 PM
houstonvett's Avatar
I searched around here and found very few threads on this subject. I will be going to get some 2011 SS black leather seats, front and back tomorrow. I was told by someone it is a direct swap, but that does sound to good to be true. If the seat tracks need to be modified I will let the Forum know. Has anyone done this mod yet since the last thread that was posted here in the Forum?
My 85 Camaro had to have the worst stock seats ever offered in a car. Those seats were pure torture and I upgraded to a 2000 TA's seat setup which is 10X better then the Camaro's seats ever were, IMO. The new SS seats are even better to ride in then the 2000 TA's seats. So if you do drive your 3rd Gen car around alot, it might just make for a nice upgrade for your Camaro. I still have the original Camaro torture seats in storage, just in case I sell the car in the future.
Old May 31, 2012 | 05:59 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Re: 5th Gen seats into a 3rd Gen Camaro
Ive heard of people wanting to...but never trying. I'm curious to see how they look! If they work...
Old Jun 1, 2012 | 12:56 PM
Got the 2011 seats today. Passanger side of the SS was crushed in from a good T bone wreck. Passanger seat frame was toast but I got all of the other pieces from it so I just have to find a new frame for the seat. Back seat in perfect shape also.
To swap out the seats will take a little fab work to get it done. The 3rd Gen seats have wider frame tracks under the seat then the newer guys. The 3rd Gen cars have a cantered bolt setup for mounting their seats and the newer Camaro's are more in a straight line then the previous years. The newer guys have J hooks on the front of the seat track and just get locked into place by pulling the seat back into place and then fastening the rear of the seat frame to the chassis with a bolt. The back of the newer seat frames also have locating pins along with the bolts to make sure the seat is installed correctly.
I will cut off the old mounting tabs from the original seats that came in the 85. It will take a little time to figure out excatly where the old mounting tabs will have to go on the newer seat frames. The newer seats are very close in size to the 2000 TA seats, so there should be no problem with the seats fitting into the 3rd Gen. cars and looking good. I haven't had the time to check out the back seat configuration as of yet. The newer version has a solid mounting frame for the seat belts that goes the width of the seat. Has the drive shaft floor tunnel radius incorparated right into the design, hoefully it is very close and can be made to work.
Old Jun 1, 2012 | 09:51 PM
The back seat set ups are completley different. The newer version is 2+ inches wider, much flatter in design, then the 3rd gen guy and will not fit. Too much cutting and BS to try to make the newer version fit IMO. Better solution is to take the newer SS seat cover off and use it to cover the 3rd Gen's back seat with the same material as what is on the SS front seats. The 3rd Gen's car's back seat has always been suspect at best, the new Camaro is keeping that trend going, IMO.
Old Jun 6, 2012 | 06:25 PM
ROCmy86's Avatar
Car: 86 IROC
Engine: 355 Stealth Ram
i hope you can get them in there thats gunna look so bad A$$
Old Mar 29, 2013 | 04:54 AM
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
any more info on this setup? im wondering about the height difference? you can make anything fit and look good while your at it, dont know why people say things wont fit if it hasent been done before! can you give us some different angle pisc? or just lay in it place and take a pic? thanks pal
Old Mar 29, 2013 | 09:36 AM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Curious to see how its going to look post pics when there in! Pretty sure theyll look nice man.
Old Mar 29, 2013 | 11:07 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Cant wait to see them in the car
Old Apr 1, 2013 | 07:36 PM
sidwyz's Avatar
Car: 1985 IROC-Z
Engine: 355 LT1
Transmission: 4L60
Axle/Gears: 3.23 Australian 9 bolt
i hope you dont give up man, looks like alot of work but you will be the only one!!
Old Sep 25, 2014 | 07:58 AM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
no up dates?
Old Sep 25, 2014 | 09:24 AM
LittleFranks's Avatar
Car: 92 Z28 Hawaiian Orchid
Axle/Gears: 3.23 Posi
Was thinking of doing the same in my car but with the 2014 cloth seats.
Old Sep 25, 2014 | 04:25 PM
GXP's Avatar
GXP
Car: 1991 Trans Am
Engine: 350 Crate
Transmission: 700R4 with shift kit
Axle/Gears: 10 bolt 2.73
Was wondering if G8 seats were on the same tracks and frame as the 5th Gens. Since I have a firebird I'd think G8 or GXP seats would look better. Would it be the same fabrications?
Edit: Obviously only front seats though.
Old Sep 26, 2014 | 01:01 PM
RSValor91's Avatar
Car: Maros: 89 Z28 & 91 RS
Engine: 350 TBI & 305 TBI OEM
Update Please!!!!
Old Mar 4, 2015 | 05:10 PM
blakecharles's Avatar
I'm bringing this thread back from the dead....
Did anyone find out any info on this? I got a full set of black SS seats that I'm going to put in. As far as size, the 5th gen seats are not too wide or long. But they are vary tall, so they sit higher than OEM.
Here is a pic with one head rest raised all the way and the other lowered
as you can see, the headrest is vary high when fully raised
Old Mar 4, 2015 | 05:14 PM
This is not a good pic but as you can see the track/rails are off by about 1in, the 5th gen seats mount wider. I Normally would cut the hardware off the stock seats and put them on the new ones, but I'm not so sure I should do that in this case.
Old Mar 6, 2015 | 09:04 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
Curious to see how this turns out
Old Jan 26, 2016 | 04:23 PM
drunck1's Avatar
Car: 1991 Camaro RS TBI Convertible
Engine: V8 305 5.0
anyone get the seats installed what's the end result
Old Feb 22, 2016 | 06:57 AM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
Any updates?
Old Jun 3, 2016 | 03:54 PM
santiclause's Avatar
Car: 1992 Camaro RS T-Tops
Engine: 305 V8 5.0L
Transmission: 4LE60 Automatic
Would like to see if anyone has successfully pulled this off before I got and drop $1000 on some 5th gen seats lol.
Old Jun 27, 2016 | 04:16 PM
Engine: 305 V8 5.0L
no end result? I wounder if you could just make your own 90 degree bracket with a mounting hole drilled in it and just weld it to the existing seat brackets/rails.
Old Jun 29, 2016 | 07:02 AM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
I would just redo 4th or 3rd gen seats for that kind of money considering rear seats won't work anyways. 5th gen rear has like a bench style rear seat.
Old Jul 5, 2016 | 01:04 AM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
I am curious about this as well, my 4th gen cloth seats are ready to call it quits. Considering how long we've had 5th gens now, this must be extremely difficult to do
Old Sep 23, 2016 | 06:02 PM
Goonybird's Avatar
Car: 87 IROC Z/305 TPI T-Top
Engine: 305 TPI -Stock as far as I know
Transmission: TH700
This sounded awesome at the beginning. Please. Don't. Stop.
Old Sep 28, 2016 | 03:01 PM
Car: 1987 IROC Z
Is their a reason your hesitant to put the stock mounting brackets on the new seats? How stable/wise would it be to Fab attempt an "extension" to that spot? Maybe even weld new bolts to the floor ? Looks too nice to pass up.
Old Oct 4, 2016 | 03:39 PM
Car: 1987 IROC Z
http://www.ebay.com/itm/1-PAIR-HEAVY...dU7uFc&vxp=mtr
Check that out, maybe that would adapt to these seats ?
Old Jan 9, 2017 | 10:58 PM
Cross fire Sid's Avatar
Car: 1983 z28 Camaro
Engine: 305 crossfire injection
Any updates on this project? I'm really considering installing 5th gen seats in my car. I'd love to see a final product.
Old Jan 10, 2017 | 12:30 AM
Twin_Turbo's Avatar
That will be really easy to fix, just weld a Y shaped tab sideways to the original rail. If you fab a U tab with a small extending lip that goes under the rail you can weld the side and a plug weld in the oriignal bolt hole. Really, if that's all that it's off...it's a super easy installation.
Too bad those seats are impossible to find here, I would rock those any day.
Old Apr 19, 2018 | 09:26 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
im picking up a pair of black cloth 5th gen front seats tomorrow and keeping my stock back cloth seats (black cloth),
got them for $120 and they will soon be a thread on third gen showing how i did it,the issue above i could have fixed
new seats,just dust,no rips,no stains
in 10 minutes or less.
Old Apr 20, 2018 | 03:14 AM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
keep is posted!
Old Apr 20, 2018 | 09:02 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
i bought the seats today and got them home,now if the weather cooperates i will put them in.i need to do some stereo rewiring while everything is taken out of the car .some cool news though, i also found out both of these new camaro seats(2012 actually) are power!!!! im trying to determine what needs power and how to go about adapting this to my non power seat trans am.this car has no options,came with a mono am radio,rollup windows,hardtop,no hatch release button.its as bare bones as you can get other than it did have air(before i got the car it was mostly removed)
Old Jun 17, 2018 | 08:34 AM
tomsaddy's Avatar
Car: 1987 GTA
Engine: TT LC9
Axle/Gears: 3.50
Any updates?
Old Jun 17, 2018 | 01:35 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
i ended up getting busy doing other stuff to the car and have been working six days a week.here is a before and after of my under-hood appearance.
before underhood pic,this spring 2018
after underhood pic,this spring 2018
i need to get a 12 volt external power source and sort out the mess of wiring connections and determine what they all do and what ones i need.
there's more electronics on one seat than there is in my entire car.
Old Jun 17, 2018 | 01:40 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
if you can figure out the power mechanism its cake to swap.i just am not good at electronic things with 5 connectors and multiple wires.but to physically bolt them in you just need a 1" x 2" x 1/4" piece of plate steel or strapping,drill two holes and bolt the seat to the adapter you made and the adapter to the car.
Old May 19, 2019 | 01:09 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
update,the two largest wires when tapped into will control everything on the seats(other than airbags obviously)
im about to go put these in because ive finally got a few hours free.this si what they look like installed in a third gen
Old May 19, 2019 | 02:06 PM
tomsaddy's Avatar
Car: 1987 GTA
Engine: TT LC9
Axle/Gears: 3.50
What back seats are those? 5th gen too?
Old May 24, 2019 | 11:26 PM
91z28ss's Avatar
Car: 1991 Z28 convertible camaro
Engine: 383 superram
Transmission: Level 4 Vigilante 3000
Axle/Gears: 3:42,Torsen, moser axles LPW girdle
Looks good for sure! But for all the effort, I would try to score some nice Z28 Recaro seats instead!!! They would look thiner compared to those bulky SS seats... I own an 2012 SS Vert and IMO the SS seats looks too bulky for 3rd Gen
Old May 26, 2019 | 03:50 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
the ss seats are definetly more comfortable,i paid $100 for 2012 camaro seats,recaros are $1000 -$1500.its all about economics
Old May 26, 2019 | 03:51 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
2 wires ,4 bolts and a little mechanical aptitude
Old May 26, 2019 | 03:55 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Old Dec 8, 2019 | 08:44 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
recaro seats in decent condition are easily $1000,these were $100....see how the math works on this?
Old Dec 9, 2019 | 09:02 AM
cdoyle's Avatar
Those look so good in there.
What center console is that does anyone know?
Old Dec 9, 2019 | 11:09 PM
  #42
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
hmmmm…. matching rears and door panels, too, nice... headrest looks a bit tall for this app.
Old Dec 10, 2019 | 05:56 PM
  #43
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
i think they actually slide down about another 1"-1 1/2" or so but i do agree they are a bit tall.
then again the 5th and 6th gen camaros are more like an suv than a sports/performance car
in the looks/size department so its much harder to tell how tall the headrest is when installed
in the 5th gen and up.
Old Dec 10, 2019 | 06:57 PM
  #44
427seven's Avatar
Really like the seat though, the headrest could be modified really easy, but that seat looks really good, looks like it fits right in width wise, too.
Old Dec 10, 2019 | 07:54 PM
  #45
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
I know,that console looks incredible too,i wonder if its custom or stock 5th gen?the interior looks so much more modern but it doesn't look out of place if that makes sense.ive got to push myself to install the pair i have.i just wish they were leather and i also would like a rear set as well.the biggest thing holding me back is the mint grey cloth interior i just pulled out of a gta i parted out.i already installed the seats in my t/a and they look and feel great.i guess its always good to have a few options.ive got 3 sets of seats,4 sets of rims,3 spoilers,3 spare engines ,engine parts etc etc etc.im a bit of a pack rat for third gen stuff.
Old Dec 10, 2019 | 07:57 PM
  #46
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
im thinking its custom but the double cup holders,the switch panel,hell all of it looks great.
Old Dec 19, 2019 | 09:36 AM
  #47
iroc45's Avatar
what vehicle console is that from? Looks great what you have done.
Old Dec 19, 2019 | 04:25 PM
  #48
cdoyle's Avatar
Does anyone have more pictures of that car, would love to see how it fits into the dash/stereo area
Old Dec 19, 2019 | 05:13 PM
  #49
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
no,but if im not mistaken its a hawks car(i could be wrong though)it seems like it would be like any fabrication project,it takes time,trial and error.make it out of cardboard or masonite as a prototype,then make the real thing out of "whatever" delrin,aluminum????
Old Dec 28, 2019 | 02:25 AM
  #50
913rdgen's Avatar
What did you do for the back seat
