Shift light indicator, lights up each gear you are in?
Old Jun 9, 2012 | 10:28 AM
bmorgil's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: Chevy 383 Stroker
Transmission: Probuilt 700 R4
Axle/Gears: 3.73 with a Detroit Locker
I am looking for a light indicator that can light up each gear i am in. I dont think any of these came stock, just the whole area lighting up when the lights are turned on. If i have to do a aftermarket piece what should i use and can i be done.
Old Jun 9, 2012 | 10:55 AM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: Shift light indicator, lights up each gear you are in?
I want to say they light up on the later model year cars...I'm sure someone will chime-in and let us know for sure.
Old Jun 9, 2012 | 11:50 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
You talking digital? There was a member (diggler86) the built one a couple years back.Here's a thread he posted.
https://www.thirdgen.org/forums/inte...dicator-t.html
Old Jun 13, 2012 | 11:47 AM
mav75's Avatar
Car: '89 Trans Am
Transmission: 700 R4
Mine doesn't. I have an '89 T/A.
Old Jun 13, 2012 | 03:40 PM
7thdarkangel's Avatar
Car: 1983 Camaro
Engine: Missing
Transmission: Missing
Axle/Gears: 9" Ford
im working on a side project that is something similar to what you are looking for. the strip will stock when off. when on all the letters/numbers will be lit up blue exept for the gear your in, that will be red. the colors are my choice someone could easily change them. but the concept/project is still in prossess.
https://www.thirdgen.org/forums/fabr...late-idea.html
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
