My awesome modded center console...
Old Jul 17, 2012 | 04:07 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I will post my build pics later...
This is what i did (Deleted the lower vents and wrapped the lower center in leather. On the top i made my own radio plate with smooth step downs to brake it up the rough look and to keep it looking factory. I completely removed the HAVC controls and put the radio in place of the HAVC controls, but that's not all i mounted the radio completely flush with the step down plate, made a space big enough to a accommodate a CD's and also added a 12volt power source left of the holder)
Old Jul 18, 2012 | 05:16 AM
BlackBandit007's Avatar
Car: 91 Z28 Vert
Transmission: Automatic
Re: The killer center console that appears to be factory - BUT ITS NOT! hahaha!
Nice job, I'm working on my center console also. I look forward to your build pics.
Old Jul 18, 2012 | 05:58 AM
LHernandezJr's Avatar
That looks awesome, and I like the idea of wrapping it with leather. May have to borrow that idea
If I was going to do something like fabricate a new center console, I'd probably eliminate the ashtray completely and in its place I'd build a small covred panel with USB, aux and other power source connectors. I'd also try to fit a cup holder somehow behind the power window switches.
So did you really eliminate the HVAC controls completely? How come you didn't go for a radio/video/navigation system screen right there.
Do people still buy/use CDs? JK
Old Jul 18, 2012 | 01:51 PM
FueledSoul's Avatar
Re: The modded center console that appears to be factory...
Yes, i have no heat or AC in my car so whats the point of running HAVC controls? lol... This CD player works good enough for what i need, i all ready have navigation on my phone and i can hook up and steam music from my phone thru the CD player... I'm sure people still buy CD's i just used a CD as reference for building a storage space. In my 4thgen i liked how i had a space to fit a phone and the lighter on the side so i kind of incorporated that idea into mine... When people where still "buying CD's" i would always have to pop the shifter back to get them into to the player and iv always wanted a flush mounted radio and in the HAVC control location... I kicked around the idea of having a compact sliding cup holder in the center and either that or one in the same spot you are talking about its easy enough to do but if you drive a stick good luck! in the 4thgen im glade they put a sliding cup holder to the side, the one in the center is FRtarted on a stick car... but i may just incorporate some cup holders in the door panels which i always felt was another bad idea from the get go because people forget them and then when they shut your door your carpet and door panel looks like a fountain drink...
Old Jul 18, 2012 | 02:30 PM
FueledSoul's Avatar
Here is the build pics
I started with a regular radio pod to make things simple but had to mod the sides...
Old Jul 18, 2012 | 02:31 PM
FueledSoul's Avatar
I had cut these off the dash
Old Jul 18, 2012 | 02:32 PM
FueledSoul's Avatar
I had to trim some of the radio pod
Old Jul 18, 2012 | 02:33 PM
FueledSoul's Avatar
Clearance between the radio and dash
Old Jul 18, 2012 | 02:35 PM
FueledSoul's Avatar
Old Jul 18, 2012 | 02:36 PM
FueledSoul's Avatar
Reinforced the sides
Old Jul 18, 2012 | 02:38 PM
FueledSoul's Avatar
Old Jul 18, 2012 | 02:43 PM
FueledSoul's Avatar
I ground down the factory rivets as i much as i could before they would lose there grip, then i used etching primer after i ground them down before i wrapped the lower center... The reason i ground them down was they were extremely visible thru the leather
Old Jul 18, 2012 | 03:30 PM
conlinj's Avatar
what paint did you use for the radio bezel?
Old Jul 18, 2012 | 04:06 PM
Great photos of the console project.
Thanks for taking the time to post!
Old Jul 18, 2012 | 06:25 PM
FueledSoul's Avatar
I used duplicolor undercoating and a semi black paint on top of it
Old Jul 19, 2012 | 04:28 AM
Car: 91 Z28 Vert
I like the trick with the rivets...thanks for posting, it has been helpful.
Old Jul 19, 2012 | 07:40 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Re: My awesome modded center console...
That looks great. The single DIN radio looks at home in that console, as opposed to the stock consoles with one.
How did you get the leather to adhere to the console? I have a "spare" Firebird center console that I've been thinking of wrapping for a while now.
Old Jul 19, 2012 | 07:45 PM
82tarecaro's Avatar
That came out nice. It looks stock if someone didn't know what was done to it.
Old Jul 19, 2012 | 11:04 PM
FueledSoul's Avatar
Thanks for the complements guys...
I used 3m 77 adhesive
Old Jul 27, 2012 | 10:33 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Very good job man, thanks for posting!
Old Jul 27, 2012 | 11:45 PM
FueledSoul's Avatar
thanks
Old Jul 28, 2012 | 12:02 AM
Camaro-Drew's Avatar
Car: 92 rs Camaro
Engine: no engine now, some sorta sbc soon!
Transmission: none now, built auto oneday!
Axle/Gears: stock now, 9" one day!!
Thanks for posting this, This was a really helpfull thread. For some reason the aftermarket radio installation kits are made so ugly, the way they "bubble" out, and I gutted all my hvac so I no longer need the controls. Hope you don't mind some of us out here stealin' your ideas!!
Old Jul 28, 2012 | 09:01 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Nice job on the console. I've done a few modifications on mine but nothing like this. I like the idea of moving the stereo farther up.
Old Jul 29, 2012 | 06:17 PM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
You did a great job!
Thanks for posting up the pictures. Now I have another project idea!!
Old Jul 29, 2012 | 06:53 PM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Great job.
Old Aug 1, 2012 | 09:46 AM
1Aauto's Avatar
Former Sponsor
Nice job on the interior.
Old Aug 2, 2012 | 10:27 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
looks real good man-good work.
Old Aug 2, 2012 | 12:13 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
looks good man
Old Nov 24, 2012 | 03:53 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Originally Posted by FueledSoul
Nice clean install! However since you made that custom faceplate why didn't you fab it up to single din specs? Rather then showing the 1.5din cutout on the outside of the single din cutout?
Old Nov 24, 2012 | 05:24 PM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Suttle and clean. Good work
Old Nov 27, 2012 | 04:37 PM
Ashton89iroc's Avatar
Car: 1987 IROC-Z
Engine: Vortec 350 crate #12530282
Transmission: 700-r4 Auto
nice job! I made a small modification to my center console as well. I was digging under my dash one day and found a key cylinder with a key and some wires coming out of it, i later found out it was the original PASS-key system. so obviously someone changed the steering columns in the car, so without the pass key in the car won't start even with the other key in the column. so for a little more convenience, using regular speaker wire i wired the PASS-key up to my center console in the compartment under the lid, kind of as a home-made cut off switch. i think its actually a really cool idea. I'll get pics up later to show you guys.
Old Nov 28, 2012 | 06:18 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Looks great fueled soul.
In my last incarnation, I moved the AC outlet to the ashtray (with a few switches) and used the lighter as a turn **** for my bass control
Old Nov 30, 2012 | 12:48 AM
MerethriX's Avatar
Car: Pontiac Trans Am GTA
Transmission: th700
nice work! but what is that button between window buttons? i got mirrorbutton there! and i surely still buy cds!!!!
Old Nov 30, 2012 | 10:25 AM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
It's the hatch pop button.
Old Jan 8, 2013 | 09:59 PM
kitt_2000's Avatar
some projects i built if anyone wants to see... I installed a full touch screen dvd player and moved the a/c heater controls to the bottom. Also shaved the knight rider console so i can use my parking brake. Thought they were good enough to share is all..
Attached Thumbnails My awesome modded center console...-img_2054.jpg   My awesome modded center console...-img_2058.jpg   My awesome modded center console...-img_2061.jpg
Old Jan 8, 2013 | 10:19 PM
kitt_2000's Avatar
Attached Thumbnails My awesome modded center console...-console-closeup.jpg   My awesome modded center console...-console-car1.jpg   My awesome modded center console...-console-car2.jpg
Old Jan 8, 2013 | 10:22 PM
kitt_2000's Avatar
These are pictures while i was test fitting everything.. I need to take pictures of it after all was finished... i came out trick.
Old Jan 8, 2013 | 10:36 PM
kitt_2000's Avatar
hErE ARE some pIctures of the ouTside of the caR when I fiNished it..
I love to drive my car
Attached Thumbnails My awesome modded center console...-my-car-rear-view.jpg   My awesome modded center console...-kitt1.jpg   My awesome modded center console...-kitt2.jpg
Old Jan 10, 2013 | 09:43 PM
Engine: LB9, LS1
Fueledsoul, where did you get the leather?
Old Jan 12, 2013 | 10:48 AM
FueledSoul's Avatar
http://www.joann.com
PurelyPMD
May 5, 2016 04:57 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
ndndndnd
Sep 28, 2015 08:00 AM
