Interior console light question
Old Jul 20, 2012 | 06:14 PM
bridgemanjr's Avatar
Car: 91 Trans Am Convertible
Engine: 305 TBI (LO3)
I need help in seeing the light, literally!!!!
I am looking for help in repairing/replacing the console light in a 1991 automatic Trans Am Convertible. This light illuminates the transmission gears [P R N D L L1] and not the one in the glove-box. Mine for some reason has crapped out and I cannot figure out how to gain access to the light so that I can see what gear I am in while driving. Any insight as to how to gain access, and then how to replace [what is the bulb size/where can I get one?] it would be a tremendous help.
Thanks in advance
Old Jul 20, 2012 | 07:35 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Interior console light question
If it's like the 86 TAs you'll have to remove two screws just under the console lid,then their is a screw under the ash tray.just lift the whole shifter plate up,you may have to remove the shift **** if you cant get to the bulb.
Old Jul 20, 2012 | 09:42 PM
it looks like this one, except mine is an automatic.
It is the bulb located under the auto shifter plate.
http://i1142.photobucket.com/albums/...orp/001-20.jpg
another shot
http://i2.photobucket.com/albums/y33...e/DSCN0005.jpg
Old Jul 20, 2012 | 09:55 PM
mantaguy's Avatar
Engine: 5.0 EFI
It's the same,just remove the screws I described and lift it up.
These two screw holes and one under the ash tray.
Old Jul 20, 2012 | 10:06 PM
thanks, now any word on where to locate a replacement bulb? size/part #?
Old Jul 20, 2012 | 10:16 PM
mantaguy's Avatar
Engine: 5.0 EFI
this is the one under the ash tray,Not sure about the bulb size,but it's a small one.
Old Jul 21, 2012 | 11:31 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Yes, these things light up, but it's more for decoration than functionality. It's pretty easy to tell what gear you're in while driving, you should run around 2k rpm at 60mph, if you're in 3rd it would be closer to 3k rpm.
Old Jul 21, 2012 | 12:49 PM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Transmission: Tremec 3550
Axle/Gears: 9 Bolt - 3:45
Welcome to the board bridgeman!
Old Jul 7, 2013 | 08:05 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
any word on the light bulb #?
Old Jul 7, 2013 | 08:51 PM
wgripp's Avatar
https://www.thirdgen.org/forums/elec...erlay-out.html
If Camaros are the same as firebirds, it looks like its a number 37 bulb
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
