Removing console clock?
Car: 1984 Z28, 2004 F-250
Engine: 305 in the Z28, 10-Cyl in the F250
Transmission: 5-Speed in the Z28, F2250=Auto
Hi,
Apologies if already asked, I cannot find it.
How does one remove the center console clock? I took the screws out around the clock but won't budge... Do I have to remove the entire center console?
Thanks,
Shepp
Thanks,
Shepp
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Removing console clock?
JamesC
Cool,
Do you have any pics of what bolts/screws to remove?
I have a NOS clock I want to put in and send my non working clock off for repairs.
Thanks,
Shepp
Thanks,
Shepp
Here's a pic of one of the three holes in the clock itself. The screw goes through the hole and into the upper console.
JamesC
JamesC
Cool,
But I have a clock and see these holes. What I cannot sort out is:
You can remove the clock by loosening the rear of the upper console and lifting it up.
How do i do this? What and where are the screws/bolts to accomplish actually pulling the old clock out?
Thanks man,
Shepp
Thanks man,
Shepp
Would I just loosen and/or remove al the torx and bolts as if I were going to remove the ctr console to do this but, then just lift the rear of the console up to access the clock/insert NOS clock?
Thx,
Shepp
Thx,
Shepp
IIRC, you can remove the two screws at the bottom of console (lift the lid to locate them), then lift the rear of the upper console, which will allow you to access the underside of the clock and the three screws securing it in place.
JamesC
JamesC
Ok the new clock is now installed...
I take it the clock is on the same circuit as the horn and dome light? My horn, dome, and now NOS clock are not working...
I need to find a good shop to take it and get this electrical issue sorted... Sigh
Thanks James.
Shepp
Thanks James.
Shepp
[QUOTE=Shepp84Z28;5339257My horn, dome, and now NOS clock are not working...
[/QUOTE]
Those are on the same fuse--probably blown. Check the following fuse diagram:
https://www.thirdgen.org/forums/elec...ml#post4350355
JamesC
[/QUOTE]
JamesC
Nice call, dome light and clock working.
Horn on the other hand... Just the relay clicking...
Thanks man!
Shepp
Thanks man!
Shepp
Do you have a diagram of where the horn(s) are? I've got a 1984 Z28 if that helps.
Ty sir,
Shepp
Ty sir,
Shepp
Open hood. Front, inside the driver's side fender.
JamesC
JamesC
Cool thanks.
I'll let you know next Saturday (that is car day, Sunday is fishing day
Shepp
)Shepp
Is there just one horn? I took a peek and do see a horn. I took the connector off and while clean, I did put dielectric grease on but still just click click from relay. Will take a better/more thorough look next week.
Ty,
Shepp
Ty,
Shepp
Some cars apparently have a single horn.
JamesC
JamesC
Picture of the Clock installed.
Yes, the second hand is red, not orange. I was driving when I took this pic, so pardon the somewhat blurry image.
1984 Clock installed in 2012
Shepp
Shepp
Transmission: 5-Speed Manual
Shepp Was It A Hassle Removing/Installing Your Clock,My Clock Works But Exposure To The Sun After 28 Years Has Curved The Second Hand Up So When It Makes A Sweep It Rubs On The Clock Lens And Stops I'd Like To Remove It To Repair Just Curious If You Ran Into Any Problems. Also, What's That Extra Screw On Your Trim Plate
Not a hassle at all once James C came along and helped me out.
I also used this video (iPad with me in the car):The trim plate on my 1984 Z28 has four of those torx screws around the plate of the clock but they appear to be all for show. I took those out first thinking the clock would just pop out of that hole, lol... but they do and hold nothing.
Shepp
