The high beam rod to the blinker switch?
Old Sep 19, 2012 | 01:00 PM
Lg486ta's Avatar
Car: 1986 TA
Engine: 5.0 lg4 carb
Transmission: 700r4 auto
My colum is cracked from someone trying to steal car. All lights and blinkers work, except to the high beams. The rod isn't connected to the switch. If I just push rod highs work fine. My ?? Is how do I attach it to the switch?? I think my switch is broken I don't see a way to connect??
Old Sep 19, 2012 | 05:10 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: The high beam rod to the blinker switch?
Sorry about that.
Old Sep 19, 2012 | 05:44 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
I think he is complaining that the OTHER end doesn't connect. Someone tried to steal the car so no doubt broke the switch at the TOP of the column. I have the same issue. There is a small plastic cam I think that the rod fits into and the dimmer stalk inserts through. The best bet is to get a factory service manual(that is on my list too!) so you can pull the wheel and access the dimmer controls to fix it. Sounds like there may not be an easier fix than that...
Old Sep 19, 2012 | 07:07 PM
Lg486ta's Avatar
Car: 1986 TA
Yes it's at the top where it connects to the blinker/wiper handle. If I push the rod by hand it works but won't pass for sticker under Safty. Something is defiantly missing/broken. I'll will get the book and see what I can find out..
Thanks guys
Old Sep 19, 2012 | 07:27 PM
Lg486ta's Avatar
Car: 1986 TA
@ micktroup2 check out this guys post
https://www.thirdgen.org/forums/susp...-steering.html.
If link don't work... Look up, How to: tighten tilt steering w/pictures
Great info and pictures.
Old Sep 20, 2012 | 06:01 PM
Lg486ta's Avatar
Car: 1986 TA
I'm missing the plastic piece behind the blinker switch/multi function switch that i think high beam rod connects too. Anyone know of this piece. In link last post it's pic 4 in part to of that guys post
Thanks for any help. Can't get sticker
GTAman
Mar 15, 2019 11:40 AM
Dialed_In
Aug 20, 2015 01:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
BBSDesigns
Aug 11, 2015 07:39 PM
