blower motor
Old Dec 17, 2012 | 11:39 AM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
blower motor
so not really sure where to post this but i was wonderiong is there a way to make the blower motor stronger? or put in a stronger one in? ive noticed the blower motors in our cars suck and then you get into a new car and its like a torando and i was wonder if it is possable tog et the same in our cars.
Old Dec 17, 2012 | 12:20 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: blower motor
Have you tried getting a replacement unit? Our heater blowers are getting old at this point and new replacement ones could be spinning a little faster now.
Old Dec 17, 2012 | 05:08 PM
DARKmj16's Avatar
Engine: 305 tbi
Re: blower motor
yes its a new one, less then a year old. but its still like stock :/ any one know if there is an aftermarket one that blows stronger?
Old Dec 17, 2012 | 06:31 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: blower motor
All right this is what I did when I did my A/C delete. I ordered an after market blower for a car with A/C. I had to make a little spacer because the squirrel cage was to deep. She really blows now, maybe just get a heavy duty replacement and see how that works for you.
Old Dec 17, 2012 | 07:36 PM
DARKmj16's Avatar
Engine: 305 tbi
Re: blower motor
i did get the heavy duty one thinking the same thing lol. but the getting an aftermarket one and making it fit might be the only way to go, which one did you get?
Old Dec 17, 2012 | 07:40 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: blower motor
The problems aren't with the motor.
1. Wiring is old. Old wiring leaves less voltage available to motor.
2. Ducts are press-fitted together WITHOUT gaskets. Over time, they come loose and air leaks. And what IS gasketed (heat duct on floor, gasket between bulkhead and heater box on both sides) tends to have the gaskets dry out after years of hot and cold, leaving more air leaks.
3. Heater core/evaporator could be clogged with the dust that gets sucked in from the cowl area.
New cars don't have any of these problems because they're not old yet.
Old Dec 17, 2012 | 07:44 PM
DARKmj16's Avatar
Engine: 305 tbi
Re: blower motor
hmm the ducts i fixed and tapped together when i took my dash a part, new heater core, but didnt think anything bout the wiring beening old.
Old Dec 17, 2012 | 07:52 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: blower motor
Check the voltage available at the motor on HIGH with the connector off of the motor and compare it to the battery voltage.
Problem with the wiring is years of corrosion on the starter terminals (where the HVAC system gets its power from the battery) and that goop GM put in the connector that joins the engine harness to the HVAC harness (next to the heater core hoses, has a big fat red wire in it along with a couple others). Clean up the connections first to try to minimize the voltage loss. May also run a new ground wire from the motor to either the engine block or body.
You never mentioned anything about the A/C evaporator in the blower case... Do you not have A/C? If not, that's one less thing to get clogged.
Old Dec 17, 2012 | 08:20 PM
DARKmj16's Avatar
Engine: 305 tbi
Re: blower motor
no i do have a/c but im not worried bout it since the comprosser doesnt work. i replaced the heater core so that area is cleaned.
Old Dec 17, 2012 | 08:26 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: blower motor
Doesn't matter if the A/C works or not. ALL of the air entering the dash ducts still goes through the evaporator whether or not it goes through the heater core. Just to the right of the blower motor you have the evaporator. There are, I believe, 6-8 screws holding the top half of the case to the other half, which you remove to get at the evaporator. The blower motor side of the evaporator is probably clogged up. It may or may not have some sort of foam on it as well, which also blocks airflow and clogs (just like the filter in your home furnace). IDK if newer cars have the foam on the outside of the evaporator or not.
Old Dec 17, 2012 | 08:43 PM
DARKmj16's Avatar
Engine: 305 tbi
Re: blower motor
ooo ok ill have to check then thanks
Frozer!!!
Jan 19, 2024 04:55 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
zayne0
Aug 24, 2015 07:22 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
