Carpet Install Question
Old Jan 23, 2013 | 04:24 PM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Is there any type of adhesive that is used under the new carpet to hold it in place?
Old Jan 23, 2013 | 04:43 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Carpet Install Question
You can use spray trim adhesive. If the carpet is a good fit you shouldn't need much.
Old Jan 23, 2013 | 05:24 PM
insomniac's Avatar
Engine: 5.7 L98
its a ACC carpet, is there adhesive used from the factory?
Old Jan 23, 2013 | 05:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No
Old Jan 23, 2013 | 06:47 PM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
you can use windshield weld ribbon type , yes there are a few spots the factory sticks down , yoou;ll see when you remave the old one.
Old Jan 23, 2013 | 07:05 PM
insomniac's Avatar
Engine: 5.7 L98
isnt that like a double sided sticky tape? is there kind of like a coating i can paint on to protect against rust and does some sound deadening?
Old Jan 23, 2013 | 07:36 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Why go through gluing,it's absolutely not required.
The mass backing will give you some sound deadening.
Old Jan 23, 2013 | 07:40 PM
insomniac's Avatar
Engine: 5.7 L98
what stops it from sliding around then?
Old Jan 23, 2013 | 07:47 PM
mantaguy's Avatar
Engine: 5.0 EFI
It wont slide around!!!their's so much holding it in place it wont go anywhere.
Old Jan 23, 2013 | 07:48 PM
insomniac's Avatar
Engine: 5.7 L98
yeah thats true... cool thanks
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
