Bad design or broken seats?
Old Jan 27, 2013 | 09:35 PM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
I've owned a Firebird and a Trans am and have noticed that in each car the clip on the back of the front seats that are supposed to let the seat fold forward are stuck and the seat can be pushed foreword without having to push on the lever. Does anyone else have this issue with their seat and is there a way to fix it?
Old Jan 27, 2013 | 09:56 PM
89iroc89's Avatar
Car: 1991 firebird GTA
Engine: 305 tpi
Transmission: 5spd
Axle/Gears: 3.42 posi
Re: Bad design or broken seats?
Lol yes I have these in all my 3rd gens and none of them work. I know they were supposed to work but they get broken too damn easy.
Old Jan 29, 2013 | 03:43 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Broken seats.
My 02 that has the same seats has always worked correctly because I've babied the car and not allowed fat people to sit in it. However, both of the base seats that came in my 91 T/A and one of the GTA seats that I bought to replace them are broken like that.
Would be interested to see a fix if anyone has one...this problem is driving me NUTS on my GTA seats. Even tried taking one apart to try and figure out a fix but got nowhere.
Old Jan 29, 2013 | 04:04 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
That is by design, the seat back go forward without the lever. However; I was told by the Dealer when my car was brand new (still own the car) the seat backs locks when the brakes are applied above a certain speed. You can try this yourself and notice the seat backs Do Not Move Forward under hard braking.
Old Jan 29, 2013 | 05:20 PM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Sounds like a engineering brain fart, adding expense of a lever just for the heck of it.....
Old Jan 29, 2013 | 05:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The lever is there so you can put the seat forward when parked on a hill.
Old Jan 29, 2013 | 05:31 PM
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
The seats are supposed to have an "inertia lock" to keep them from moving forward on hard braking or impact. They should move freely under normal conditions. A description of how they work is in the attached files.
Old Jan 29, 2013 | 07:00 PM
lonestar7's Avatar
Engine: 5.7L TPI
Umm.... The PDFs didn't load correctly. Let's see if these work.
File Type: pdf
File Type: pdf
File Type: pdf
Old Jan 29, 2013 | 09:02 PM
TheGr8erG00d's Avatar
^^ This is what I've always read. Now as to why the tabs are all broken off, you've got me on that one. Mine are broken off as well and I convinced myself that I would fix or replace the tabs for unlocking them when parked on a hill. Hasn't happened yet... Thankfully, it's not something I need regularly.
On another note, it used to be funny but now just drives me crazy that anytime someone tries to get in the back seat they scour for the tab at the bottom and don't figure out that the seat will fold forward if they so much as breathe on it.
Old Jan 29, 2013 | 10:58 PM
Axle/Gears: 3.45
Ahh it's a relief knowing that they're supposed to go forward without the lever in action. I was always hesitant of reupholstering my seats because I thought there was no point if they were broken. The inertia lock system is pretty cool
Old Jan 29, 2013 | 10:59 PM
Axle/Gears: 3.45
This, so much
Old Oct 7, 2013 | 10:31 AM
dunkirk's Avatar
Originally Posted by navy02ws6
Broken seats.
Mine does the opposite, they won't let the seats move forward???
Old Oct 13, 2013 | 04:59 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The 2002 seat and the 1991 seat may look the same, but they are not. The lever must be lifted to move the seat forward on the 4th gen cars. Your thirdgen seat is working properly. It should move forward without lifting the lever. That lever is there only to allow you to move the seat forward if parked on a hill (which would trigger the inertia lock). There are instructions in the Service Manual how to test the angle at which the seat inertia lock will engage to determine if it is functioning properly.
Lon
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
