Adding Rear hatch release???
Old Mar 20, 2013 | 09:34 AM
IRC Z28's Avatar
Car: 86 IROC Z
Engine: 305 5.0
I'll be taking a recently purchased Iroc out of storage next month to start getting it to look like I want for my mid life crisis rebuild. I'd like to add a rear hatch release. It's currently non existant in the car...Is this something that can be done? I'll be removing the interior and thought this might be a good time to look into it...
Any help or thoughts are appreciated.
Old Mar 20, 2013 | 08:24 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: Adding Rear hatch release???
Parts are available and the wiring harness should already be there in the car to accommodate the upgrade, although you did not mention what year it is. Good luck with your project.
Old Mar 21, 2013 | 07:05 AM
IRC Z28's Avatar
Car: 86 IROC Z
Engine: 305 5.0
Thank you for the reply...It's an 86 Iroc...Will it be as simple as mounting the release switch and tying it into the relase hatch wiring harness? Sounds to good to be true.
Old Mar 21, 2013 | 07:28 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
I know there's some sort of control, a relay perhaps, that prevents you from "accidentally" releasing the hatch when you're driving, so it won't be plug and play.
Old Mar 21, 2013 | 08:54 AM
tavert91's Avatar
Engine: LB9 5.0 TPI
Transmission: 5 SPD
And don't forget, you will need to mount the dash switch that controls it.
Old Mar 21, 2013 | 02:02 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I've done it and it is almost plug and play as all the wiring and connectors are in place. You'll need the dash switch and cover with the extra hole. The connector is tucked in behind the cover. The connector to plug the relay into is under the passenger side of the dash. Tucked in and not easy to get at but do-able. I skinned a knuckle. Then in the trunk replace the manual release with the solenoid release. The wire for the solenoid should just be hanging there somewhere. I swapped the parts from a donor car and bought the switch and dash plate from Third Gen Ranch.
Old Mar 21, 2013 | 02:33 PM
IRC Z28's Avatar
Car: 86 IROC Z
Engine: 305 5.0
Thats some great detail...Thank you so much. Sounds easy enough. I just need the parts.
Do I need a whole new cover or can I mount the switch to the existing one?
Old Mar 21, 2013 | 02:55 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
It's just the narrow oblong part that comes off separately. Mine just had a fog light switch. I was going to cut a hole then saw one with two holes already so bought that one. Check Third Gen Ranch for covers and switches. They don't always have them but worth a try.
Old Mar 21, 2013 | 02:57 PM
IRC Z28's Avatar
Car: 86 IROC Z
Engine: 305 5.0
I sure will...thanks again for the great info.
Old Mar 21, 2013 | 07:17 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
i did this to my car.i hooked it directly to my aftermarket remote power door lock module.btw some of the later camaros had pull down motors and used different rear latches.i don't know if the power release module fits all year cars.
Old Mar 21, 2013 | 07:43 PM
IRC Z28's Avatar
Car: 86 IROC Z
Engine: 305 5.0
It's only the fourth year with an August build...guess I won't know till I take it apart.
Old Mar 21, 2013 | 10:39 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Here's a pic of the wiring and relay you will need.
Notice the 2 wire plug at the top of the wiring bundle. The male end of this connection ( connector C241 ) will be hidden inside your center console. Simply plug the relay in at this spot, mount the button, run the wiring to the hatch, mount the soleniod - done. The set-up pictured above is $55 + shipping,... everything you'd need. Send me a PM for details if your interested.
FYI: You must use a Release Soleniod from an 82-85,..... the 86-91 "PPD" version of the soleniod will not mount properly to your hatch latch.
This should help too: Here's the Wiring Schematic for your 85:
Old Mar 22, 2013 | 06:16 AM
IRC Z28's Avatar
Car: 86 IROC Z
Engine: 305 5.0
John,
Great stuff there, thank you.
To confirm...I own an 86 model year. Will the above set up work with my car? You mention the release seleniod being different after the 85 model year. Ifnot, do you have the 86 PPD version?
Old Mar 22, 2013 | 09:53 AM
John in RI's Avatar
Wow; I'm an idiot !! Not sure why I had an 85 set-up in mind while writing this ! I think it's cause I had just written to someone about an 85 coupe nose..... Whoops !!
Just about all the details above are the same for your 86 IROC. The one and only thing that would change is the actual release solenoid. You would need to use the 86-91 style Solenoid ( yes - I have this one. )
Sorry I didn't pick up on that sooner !
Old Mar 22, 2013 | 10:32 AM
IRC Z28's Avatar
Car: 86 IROC Z
Engine: 305 5.0
No worries John,
Same deal $55 + shipping?
At that point, all I'll need is the switch?
Old Mar 22, 2013 | 03:20 PM
John in RI's Avatar
Yup, same deal,....... and the Hatch Release Switch is already included.
With the smaller soleniod this stuff might even fit into a small flate rate package. I'd need your ZIP to get an exact shipping quote for Ya'.
Old Mar 22, 2013 | 03:36 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
And don't forget to post some pics of your "mid-life crisis" when you get it out of storage. Good luck with your project.
Old Mar 22, 2013 | 06:04 PM
IRC Z28's Avatar
Car: 86 IROC Z
Engine: 305 5.0
John,
Thanks so much...I'm just up the road a bit in Framingham....01701
Let me know what you want to do.
Rich,
I'll post before, during and after pictures. My wallet needs to catch up with my wants.
The car it's nice the way it sits, but not exactly the way I want it to look.
Old Mar 22, 2013 | 11:12 PM
Richboll's Avatar
Engine: 305 TBI
Well, as I said, Good luck with it. My 3rd gen isn't a mid-life crisis as I've had these kind of cars my entire driving life, but I appreciate anyone that appreciates them so I'm looking forward to seeing yours and what you do with it.
Old Mar 23, 2013 | 07:34 AM
IRC Z28's Avatar
Car: 86 IROC Z
Engine: 305 5.0
Ohhh it's not my first one at all. This is my fourth one in the last twenty five years...I just didn't expect to own one again at this stage of my life, hence my mid life crisis....looking forward to enjoying it with my young daughter.
Old Mar 24, 2013 | 03:06 PM
IRC Z28's Avatar
Car: 86 IROC Z
Engine: 305 5.0
John,
Just a reminder that I am interested in that set up.
Get back in touch when you can.
Thanks.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
