stick swap
Old Mar 26, 2013 | 08:05 AM
1985chevydude's Avatar
Car: 1985 chevy camaro,z28
Engine: crate 350,headers,3in exhaust
Axle/Gears: 308------3.73 auburn unit
stick swap
Hey, i was wondering if anyone knew if the bracket for auto matic is the same for manual.I have a 1985 z28 camaro and i was planning on making it stick.I was also wondering if i should go the z bar route or hydralic thank you.
Old Mar 26, 2013 | 10:37 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: stick swap
Which bracket do you mean?
Old Apr 2, 2013 | 10:17 PM
rockstarr4's Avatar
Car: '84 Camaro - 2010 Surf Blue
Engine: 305 - 4 bbl Holley
Transmission: WC T5
Axle/Gears: 3.08
Re: stick swap
I have done this swap and I would recommend you go with the stock hydraulic clutch linkage. It works very well as designed with the stock clutch pedal. If you are talking about the transmission crossmember as your "bracket", yes they are the same.
When I did this swap, I bought a 91 Firebird parts car for $500. Removed all the parts I needed to do the swap and then sold the remaining car for $400 plus sold my original auto trans for another $275. The extra money helped to pay for a new clutch, flywheel facing, new master & slave cylinders. So, it can be done pretty inexpensively if you have time to wait for the right opportunities.
Old Apr 3, 2013 | 06:12 AM
KhaosTactic's Avatar
Car: 1985 Black z28 T-top, 09 eclipse
Engine: Carb'd 305 soon to be a 400 sc
Transmission: 700r4 to T5 swap
Re: stick swap
Just like rockstarr said, depending on the route you go it could bolt right up. I'm in the middle of this swap at the moment in my 85 z. I went with a temporary T5 on hydraulics and everything bolts right up.
AussiePr0nCar
Mar 6, 2020 04:04 PM
lt1z350
Aug 28, 2015 05:57 AM
Bert87
Aug 23, 2015 03:50 PM
Wife'sCar
Aug 22, 2015 01:46 PM
rsrmoore
Aug 7, 2015 08:44 PM
