Vent Question??
Old Aug 20, 2013 | 03:05 PM
IrocJoe1988's Avatar
Car: 1988 Iroc
Engine: 5.7 tpi
Vent Question??
So all of the vents in my dash are completely loose, they tend to swing around in my 88 IROC with every stop and go, or turn that I make. Anyone else have this problem? And, what is the easiest fix?
Old Aug 20, 2013 | 03:36 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: Vent Question??
Don't Think There Is Much You Can Do ,They Just Loosen Up As They Age Mine Do The Same Thing.
Old Aug 20, 2013 | 03:45 PM
OdieTurbo's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 3.4L V6
Transmission: T5 (NWC)
Axle/Gears: 3.42 Stock axle
Re: Vent Question??
There's a technical article about fixing them here.
Old Aug 20, 2013 | 03:50 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: Vent Question??
Cool, never knew about the tech article. I have been using a 50 cent piece for each of the center vents. I'll try this now.
Old Aug 21, 2013 | 02:24 PM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
Re: Vent Question??
I didn't know about the tech article either, but I used automotive silencer tape on mine. Same result.
Old Aug 22, 2013 | 02:57 PM
Mikeo91's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Re: Vent Question??
Tried the Velcro trick today, works sweet. Good chance to clean everything.
Old Aug 22, 2013 | 07:30 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Vent Question??
I put small x-section o-rings around the pins.
Old Aug 22, 2013 | 08:32 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Vent Question??
1/4" wide foam weather strips (the kind used on screen doors) work very well . just a small strip on end of vent louvers . has worked for me on all of my cars/trucks . good luck .
chazman
Aug 28, 2018 03:25 PM
Todd84Z
Sep 4, 2015 08:02 AM
redmaroz
Aug 16, 2015 11:40 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
mustangman65_79
Aug 11, 2015 03:17 PM
