anyone tried intellitronix dash cluster for camaro?
Old Aug 25, 2013 | 07:10 AM
Exurok's Avatar
Car: 1982 - z28
Engine: 5.7 - 350
Hey is it worth it? Looks pretty darn sweet, if someone is using it or know someone that is i would be glad to hear what their experience is with this thing. http://www.intellitronix.com/camaro.html
Old Aug 25, 2013 | 08:05 PM
Kornis's Avatar
Car: 1986 IROC Z28 Camaro
Engine: 305 4BBL
Transmission: 5 speed Manual
Axle/Gears: 373 Limited Slip
Re: anyone tried intellitronix dash cluster for camaro?
Originally Posted by Exurok
Hey is it worth it? Looks pretty darn sweet, if someone is using it or know someone that is i would be glad to hear what their experience is with this thing. http://www.intellitronix.com/camaro.html intellitronix digital in my 87 IROC driving at night - YouTube
I like it, but 500.00 is pretty steep
Old Aug 25, 2013 | 08:54 PM
cdoyle's Avatar
They are a cool idea, but I just can't get over how cheap the displays look.
For example, instead of H20 or ELEC. Why couldn't they use a symbol for those that light up.
And the segmentation of the LEDs, why are they so huge? Smaller ones and more of them would look so much better and look more accurate when they increase.
For $500 I would just expect something that didn't look like it was done in an electronics class.
Old Aug 25, 2013 | 11:28 PM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
That's the company that took over the people that did my gauges... I dig mine a bit more - the labels are nice and minimal.
Old Aug 27, 2013 | 03:35 AM
Exurok's Avatar
Car: 1982 - z28
Engine: 5.7 - 350
Wow thats nice! Is that same cluster you got there still for sale? i mean since that company was taken over by these new folks.
Old Aug 27, 2013 | 08:09 AM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
i like the multi colors on the cluster, like the factory tach that the led bar goes from green to yellow to red
Old Aug 27, 2013 | 04:50 PM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Axle/Gears: 3:73
I'm not totally sure on that, it seems they decided to go a bit overboard with the un-needed redesign... You can ask because basically all it is in place of the lettered LED's, is a single LED with a stenciled out Black Out film over top with it's correct gauge label... You might be able to find a set up on EBay... The Company is Called - Nordskog Performance...
Old Aug 27, 2013 | 05:25 PM
cdoyle's Avatar
I never noticed this before, but check out the fuel gauge on this thing. It's all over the place. That can't be how it really works is it?
Another thing I remember about these in another thread, you lose your trip gauge I thought. And the mileage one resets if your battery goes dead, is that still the case?
Old Sep 2, 2013 | 02:30 AM
Jared N259's Avatar
It looks like it increases when he's accelerating, it might not be a tank cage, maybe it's a pressure? I don't know, looks a bit sketchy to me.
Old Sep 2, 2013 | 03:31 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
The gas gauges in all of these cars are bad. Sounds like exactly what my car does. The float just moves around as fuel sloshes. Some cars use a special time-delayed reading and wont let fluctuations like that register. (You can fill a car up with gas and it will take a few minutes to show up, for example) But our cars the gauges pick up the sloshing all over the place. Levels go down under braking and up under acceleration.
Old Sep 2, 2013 | 07:24 PM
cdoyle's Avatar
Mine doesn't do this, maybe if I really hit the brakes it will move but it's not that bad. I bet because it's a number on these gauges it seems more drastic than what a needle would show.
I just think for the price these things cost, and with the technology advances since the 80's these could look so much better.
What I would really love to have are gauges that have backlit LCDs. Where you could customize the look to pretty much anything you would like.
Old Sep 3, 2013 | 10:12 AM
Beater79TA's Avatar
Yeah, the fuel gauge moves a lot on the Intellitronix panel. Every time you corner, brake, etc the float in the tank moves and it registers on the gauge. You get used to it though.... My factory gauges do it too if I let the tank get below half and then throw it through some hard cornering.
Old Oct 2, 2013 | 03:20 PM
Exurok's Avatar
Car: 1982 - z28
Engine: 5.7 - 350
Thanks for all replies!
Old Oct 3, 2013 | 08:58 AM
No4Play's Avatar
Car: 1992 RS Heritage Edition
Engine: LS6 Mut
Axle/Gears: Stock
I'll be installing a set when mine arrive. I'll post pics and vid of them in action.
Old Oct 8, 2013 | 06:23 PM
STREETDEMON's Avatar
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
looks too much like the star wars dash in a C4, different but not for me....
Old Oct 9, 2013 | 08:58 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Can you dim down the LED's so you can see the road at night?
Old Oct 9, 2013 | 09:04 AM
Beater79TA's Avatar
One of the wires hooks to the headlight switch to dim the LED's at night. It isn't adjustable like the factory dash lights but it does dim them when the headlights are on.
Old Oct 9, 2013 | 09:42 AM
Edwardgp's Avatar
Engine: 454-350
Thanks Beater, was wondering how they had that set up.
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
tnrednneck
Aug 13, 2015 08:57 AM
ChevyZ71
Aug 13, 2015 07:30 AM
Vintageracer
Aug 11, 2015 08:13 PM
