85 to 86 dash instrument swap help.
Old Aug 25, 2013 | 05:50 PM
CamaroPaul's Avatar
Car: 1986 Camaro Sport Coupe
Engine: 2.8L V6 Multi-Port Fuel Injection
Transmission: 700R4 / 4 Speed Automatic
I have a 1986 Berlinetta Sport Coupe in the instrument panel it has the big gas gauge instead of the tach, and the temp, oil and voltage gauges are the warning light style. I got the actual tach with oil pressure, temp, voltage and small style gas actual gauges out of a 1985 Berlinetta sport coupe with the v8 my 86 is the V6 will these gauges work in my car if I just swap them out?
Old Aug 26, 2013 | 06:57 AM
cdoyle's Avatar
Re: 85 to 86 dash instrument swap help.
No it won't work with just swapping, you'll also need to replace the sending units for the water and oil. Plus since the replacement was out of a V8, the tach is going to be off some.
Old Aug 26, 2013 | 08:28 AM
CamaroPaul's Avatar
What does the sending unit look like?
Old Aug 26, 2013 | 08:45 AM
CamaroPaul's Avatar
And is their a way to make the tach compatible with the 2.8?
Old Aug 26, 2013 | 09:32 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Your don't own a Berlinetta - you own a Sports Coupe. Your parts car is also a Sports Coupe. It says "Berlinetta - Sports Coupe" on the license plate holder because those are the cars that plate holder will fit on.
The parts car cluster itself is a plug & play installation. Once installed you will have to change a couple sending units on your engine like cdoyle said.
Yes - the V8 tach can be modified to read the proper RPMs for your V6, but it's really not worth the trouble. Just buy - or trade - for a V6 tach to save yourself a lot of grief, aggrivation, time & $$.
Old Aug 26, 2013 | 09:48 AM
CamaroPaul's Avatar
https://www.thirdgen.org/1986-chevy-camaro, this tech chart shows I own a sport coupe berlinetta, but thank you for the tip.
Old Aug 26, 2013 | 10:23 AM
John in RI's Avatar
FYI: That chart simply describes what engine/tranny combinations were available in all cars in 1986. Since the V6 was only offered in Coupes and Berlinettas they are both shown as the only cars listed with a V6.
Unless your 86 has an interior that looks like this - you own a Sports Coupe.
Old Aug 26, 2013 | 11:00 AM
CamaroPaul's Avatar
Thanks for the clarification. Do you have any links to the the said parts/changes that I would have to make to get these new guages to work in my car?
Old Aug 26, 2013 | 05:02 PM
John in RI's Avatar
ANY auto parts store can get the sensors you need. Just specify V6 Temp and Oil Pressure Sending units for a GAUGE cluster.
Ghettobird52
Jul 5, 2024 11:18 PM
Jorlain
Aug 24, 2022 05:11 PM
Jeremys87
Jul 14, 2022 09:08 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Vintageracer
Aug 11, 2015 08:13 PM
