door lock rod clips
Old Sep 6, 2013 | 09:16 AM
tesar1's Avatar
door lock rod clips
Hello. I drive a 92 v6 camaro. Recently I had my lock cylinder broken out. Fortunately the car was still locked when I found it and nothing was taken. I got these cylinders
http://m.autozone.com/autozone-mobil...9ci7j?id=12489
And this clip
http://m.autozone.com/autozone-mobil...ik1b?id=103034
I have not tried fixing it yet but my concern is this. The clip attaches snuggly too the end of the cylinder but I think that as soon as a little weight is the rod is attached, it will just fall off. Is there another piece I need to ensure it stays on the end of the cylinder? Or will this suffice? Or should I glue this on? Thanks for the help
Old Sep 6, 2013 | 11:49 AM
toomany's Avatar
Re: door lock rod clips
You need the lever that connects the lock rod to the lock cylinder. The plastic clip you have holds the rod to that lever.
Old Sep 6, 2013 | 12:43 PM
tesar1's Avatar
Re: door lock rod clipsy
Where can I get one and what's it called? Just a lock lever?
Old Sep 6, 2013 | 12:54 PM
tesar1's Avatar
Edit: sorry form posting twice. It sent me to a third party site so I hit the back button and it sent me back to my message so I thought it didn't post. I apologize
Old Sep 6, 2013 | 02:47 PM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Your probably going to have to pull one from a yard to get that part off it, I don't think it is re produced.
Old Sep 6, 2013 | 02:57 PM
tesar1's Avatar
Thanks for your help.
Old Sep 6, 2013 | 03:47 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Maybe This Will Help.
Old Sep 7, 2013 | 09:56 AM
tesar1's Avatar
Diagrams are always fantastic. Thanks for that
Old Sep 8, 2013 | 03:56 PM
kx3g's Avatar
Car: '89 Formula
Engine: L98 350
Don't mean to hijack this thread, but I was just working on my locks and was needing a diagram. This one is close. I have power locks. If I look at this correctly, part 29 goes to the lock itself. Im assuming part 29 ultimately attaches to the longish rod (the acuator is in between part 29 and the long rod) that runs to the lock hanldle on the door. Is there a plastic piece that part 29 attaches too? The reason I ask is because I got some pieces of plastic out of that area..
Thanks,
Chris
Old Sep 9, 2013 | 01:42 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Did you find the clips as I can see if I have a few if you need them
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
mantaguy
Sep 1, 2015 08:39 PM
