Need a fix for the rear interior panels with carpeting
Old Oct 5, 2013 | 05:03 PM
'86 Sport Coupe's Avatar
Car: 1986 Camaro Sport Coupe (Part Out)
Engine: 2.8 MPFI V6
Transmission: 700R4 Automatic 4 speed
Axle/Gears: 3.42 Open With Drum Brakes
I have an issue with the rear interior panels in my car. The glue that held the carpeting on has given out. Does anybody know of a good fix to get the carpet to attach back to the panel? Anybody know the cause of this? Could the buildup of heat inside the car during the day weaken the glue bond? Anyway if you know of the correct kind of glue to use to get the carpeting to stick then let me know.
Old Oct 5, 2013 | 06:49 PM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Re: Need a fix for the rear interior panels with carpeting
You can get 3M spray adhesive for cloth/carpet at any auto parts store.
The cause of the separation is most likely just age. Yes, heat, extreme cold, and especially moisture will accelerate the failure point, but remember the newest car in this generation is 21 years old. Stuff just "wears out" unfortunately.
Old Oct 5, 2013 | 10:29 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
I agree and while you are there, buy some adhesion promoter to use after you clean the part first. This will eliminate the need for a repeat repair
Old Oct 6, 2013 | 10:14 AM
Engine: 2.8 MPFI V6
Thanks for the info guys. I'll keep the adhesion promoter and the 3M spray adhesive in mind!
Old Oct 6, 2013 | 10:53 AM
82tarecaro's Avatar
You may want to try brush on contact cement. You will be able to put it exactly where you want it with a brush. The spray on adhesive might get a bit messy and get on parts of the panel that don't get covered.
Old Oct 6, 2013 | 11:06 AM
Engine: 2.8 MPFI V6
That sounds like a better idea to get the carpet to stick. I'll keep this in mind too.
Old Oct 6, 2013 | 02:49 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
You can always tape off the area where you don't want over spray with painter's tape and newspaper. Well that is if you plan on taking out the panel to do the work.
Old Oct 6, 2013 | 03:08 PM
Engine: 2.8 MPFI V6
The panels are loose so there is no issue with that. I'm trying to find a way to make them sellable as they are out of my parts car.
Old Oct 6, 2013 | 03:17 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Old Oct 9, 2013 | 08:17 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Well, I'll say this:
When I went to remove the carpet pieces to paint the panels without getting the carpet, I left the panels out in the sun for several hours to bake. Getting the carpet off was MUCH easier after that (but it was still a pain).
To put the carpet pieces back on, I used 3M double-sided Permanent Mounting tape. It's gray and comes in something like 3 foot rolls (this stuff is THICK foam tape, not that cheezy stuff used for window sheeting). Unfortunately, you won't be able to use the last few inches on the roll (good luck getting it off), and it's $8 a roll (you will need at least 3 rolls... I'm a few inches short on one panel).
Old Oct 9, 2013 | 11:57 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
any walmart also shoegoo comes in a tube. will hold like its been welded!
Old Oct 10, 2013 | 10:08 AM
Engine: 2.8 MPFI V6
Lots of good ideas to fix this issue...I'd like to hear more of them if anybody else has tried something else!
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
AkDrifted
Aug 17, 2015 07:45 PM
Exxon Limited
Aug 9, 2015 08:13 PM
z28addict8490
Aug 7, 2015 08:48 PM
