rear hatch pull down motor
Car: 88 IROC
Engine: 5.7 TPI
Ok so I went out to the car the other day and unlocked the trunk with the key. When I raised the hatch the pull down motor started running. It kept running and won't cut off and I can't close the trunk now. I don't drive the car much so I just disconnected the battery for now and left it alone until I have more time to fool with it. Any ideas of what's going on with it or what to do? I've never had a problem with it before now.
Car: 85 IROC / 92 Z28 Vert / 57 210
Engine: L69 / LB9 / LQ4
Transmission: T5 / T56 / 4L65E
Axle/Gears: 3:73 / 3.73 / ?.??
Re: rear hatch pull down motor
Sounds like something broke (duh...) My guess probably the guides. Call Lon at Top Down Solutions - he is pretty much the expert at pull down motor assemblies and as far as I know the only guy who sells repair guide for them.
Axle/Gears: 3.45, 3.27, 3.27
Car: 1991
Engine: stock 305
Transmission: 5 speed standard
Axle/Gears: stock
i have several hatch pull down assemblys and all need the plastic guides,can you help with finding them. also do they make just a manuel latch.mines a 91 r/s
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
There is a manual latch, but it has a different bracket attaching to the rear bulkhead, so you will need to cut off the power bracket and weld on the manual before you install the manual latch. The best thing to do is cut the whole section of bulkhead out of a junkyard car so you can see where it mounts, there are no obvious reference points.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Lon
