custom steering wheel install
Car: 1987 firebird formula
Engine: 305 to 350 transplant
Axle/Gears: standard
Has anyone removed a steering wheel from the hub to install a custom
wheel? How is it attached? Looks like rivets but I hesitate to drill them
out. Any hints / horror stories ?
Transmission: Pro-built 700R4
Re: custom steering wheel install
Not very hard at all. I have no idea what rivets you are talking about.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
It is a commonly replaced/upgraded part. Since you have a pre 90 Fbody you should have no air bag to worry about. Should be able to just remove the horn button, attach a steering wheel puller and remove. Grab a Haynes or Chiltons from any auto store.
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
i believe hes wanting to USE the OEM hub and replace the OEM steering wheel with a different one instead of using an installation kit
After I replaced my wheel with an aftermarket, I got to looking at it and thinking " did I buy the installation kit for nothing" because the factory wheel had a 6 bolt hub that it mounted to. My grant has a 6 hole pattern too. No dice, the pattern is a different size and it will not fit aftermarket wheels.
Car: 87 Trans Am
You have to get the install kit i tryed on my 87 with out the install kit and if you dont use it the new steering wheel dosent sit flush
Car: 1986 IROC-Z
Axle/Gears: 4:10
Should be straight forward. I had to buy an install kit and modify it a bit with a rotary tool. The wheel hub would bind up and give me hell in steering. Once I ground down the burrs on there it was good to go!
Sorry, guys, I haven't been watching my messages. Thanks for the input. As mjdavis68
says, I am planning on using the existing hub. Haven't worked up the nerve to try to
remove the old wheel yet as my car is my everyday driver.
backtothe80s
Sep 5, 2015 12:39 AM
