88 steering wheel on a 92
Old Nov 5, 2013 | 07:04 PM
mikey8494's Avatar
Car: 1986 camaro iroc z
Axle/Gears: stock
i own a 1992 firebird and want to put the airbagless steering wheel from a 88 trans am on it what do i need to do will it bolt right on?
Old Nov 5, 2013 | 11:30 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: 88 steering wheel on a 92
When I tried replacing my '91's steering wheel with a three spoke airbagless one the bottom of the wheel would rub and catch against the column. I had to replace the top of the steering column housing with an older model and also get an ignition cylinder to match. My VATS was already deleted by the previous owner.
Old Nov 6, 2013 | 12:26 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
I swapped a 3 spoke wheel (85-86?) to my 91 with no problems. Everything bolted in. Had to clip a yellow wire in the column that went to the airbag wheel to get the new one in.
You'll want to remove the bulb for the airbag light from the cluster when you're done so you don't have to stare at it every time you drive the car.
Old Nov 6, 2013 | 06:00 PM
mikey8494's Avatar
Axle/Gears: stock
ok cool
83 Crossfire TA
Jan 3, 2016 01:26 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
