Window help please
Old 01-01-2014, 04:21 PM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Window help please
Alright so after the rewire of my 86 with a 00 harness my pass window wont roll down all the way it gets stuck halfway I know the wiring is all correct so it has something to do with the mechanism's in the door but I dont know what.
Has anybody had this problem?
Old 01-01-2014, 04:24 PM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
Re: Window help please
Your most likely going to have to pull the door panel of and inspect the window. You should be able to watch the window roll down and see what is causing it to stop.
Possibly a track that is out of place and needs to be adjusted.
Old 01-01-2014, 04:39 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
Door panels off and where it stops I cant see, felt around and all seemed to be on the tracks
Old 01-01-2014, 05:17 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Clean and lube the tracks really well. There may be some sort of failsafe in the later harness that is shutting the motor off after a certain amount of mechanical resistance is reached, which increases the current pull through the system. Like a circuit breaker.
Old 01-01-2014, 08:52 PM
TheExaminer's Avatar
Car: 92 Formula WS6, T-top
Engine: 5.7L T.P.I.
Axle/Gears: Limited slip, 3.23 10 bolt
Is the motor ok? I had a problem like that with my 98 Camaro and had to replace the window motor.
Old 01-01-2014, 10:50 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
i would assume its okay it acts like it wants to pull it down
Old 01-01-2014, 11:09 PM
Joe Tag's Avatar
Will it move again after a cool down period? Try cleaning and lubing the tracks with lithium grease. There is a thermal overload protector in the motor itself and a circuit breaker in the fuse panel. When the mechanical resistance is too much it will trip one of them.
Old 01-01-2014, 11:23 PM
Engine: 5.7L T.P.I.
Yes. Thats what my motor did. It would stop, then work again a few minutes later. I just replaced it. Not very expensive, and took about an hour in my yard. Had to drill out rivets and etc., but not too bad a job. Has worked just fine ever since.
Old 01-01-2014, 11:50 PM
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
moves fine up and down np just wont go down past the halfway point
Fireslash
04-11-2016 06:43 PM
jrdturbo
03-31-2016 02:58 PM
Cam-aro
Camaros Wanted
11-12-2015 03:35 PM
Bubbajones_ya
10-25-2015 08:01 PM
kkirch15
09-30-2015 04:44 PM
Quick Reply: Window help please
