what the bleep is this fastener?
Old Jan 1, 2014 | 08:13 PM
TheExaminer's Avatar
Car: 92 Formula WS6, T-top
Engine: 5.7L T.P.I.
Axle/Gears: Limited slip, 3.23 10 bolt
About a half dozen things I need to do to the inside of my door (92 Formula) but I encountered this fastener behind the door handle. Usually there is a screw here in every other car I've worked on, but I've never seen one of these before. Some kind of aftermarket deal? Its metal and looks like it's pressed into place. I can't see behind it to see if there is a nut.
Old Jan 1, 2014 | 08:25 PM
racerx520's Avatar
Re: what the bleep is this fastener?
youre kinda right, its a clip that covers a screw behind there. if you get a pick it'll pretty much just pop out with no issues.
Old Jan 1, 2014 | 08:44 PM
Engine: 5.7L T.P.I.
Ok. I will try a fine pick or something. Thanks.....
Old Jan 2, 2014 | 01:19 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Flathead screwdriver works too
Old Jan 2, 2014 | 07:32 PM
Engine: 5.7L T.P.I.
I ended up using the tip of a small scissors and it popped out. The flathead I used before I started this thread wasnt thin enough. This was a fairly easy victory. LOL My worry was that some sound guy or mechanic had busted out the plastic around the screw hole and inserted that button to hold the bezel in place. But nope, just a 20 year old design that I had overlooked when I had a car like this 15 years ago. Im remembering a lot of things I had forgotten.....
ktthecarguy
Jul 5, 2020 11:46 AM
Bohemian
Aug 15, 2017 05:11 PM
91TealRS
Jul 2, 2001 12:09 PM
True Power
Nov 17, 2000 04:24 PM
