manual window conversion.
Old Feb 9, 2014 | 01:13 AM
crazybird's Avatar
Car: 1987 firebird
i am looking to convert to manual windows. can any one help wit pics, info or parts?
Old Feb 9, 2014 | 08:58 AM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Re: manual window conversion.
I haven't done it myself, but it would be pretty straight forward:
Manual window regulators(apparently these are not available new. You will have to get them from a junkyard/ebay/site classifieds).
Window cranks.
Door panels from a manual window car, or cut the holes in your existing panels.
Remove the power regulator/motor assembly.
Remove the wiring for the power windows, or just let it hang out in the door.
If you are going to remove it, don't just cut it off. Go the extra mile and completely remove it. You may need it in the future, or someone else might.
Install the manual regulator assembly.
Install the door panels and other pieces to finish the job.
Old Feb 9, 2014 | 09:38 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Old Feb 9, 2014 | 11:58 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
This picture shows the mounting holes you will need to use when re-mounting the window regulators to the doors. Obviously; this is a manual window door.
With Power Windows , The 2 FRONT rivets holding the regulator in place are located in the front mounting holes closest to the FRONT of the car (See yellow circles).
With Manual windows, The 2 FRONT rivets holding the regulator in place are located in the front mounting holes closest to the BACK of the car. (See yellow circles)
The other 2 regulator mounting holes ( red circles ) will line up with the right door holes once the front 2 are in set in the right place (depending on the swap. )
I've got a set of manual window regulators available,... if your interested in a set just send me a PM that includes your ZIP code and I'll reply with all the details.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Veaceonee
Sep 29, 2016 08:15 PM
RyanJB
May 7, 2016 06:23 PM
Magman
Sep 12, 2015 11:55 PM
Fronzizzle
Sep 8, 2015 12:10 PM
