4th gen rear seat belts don't fit well
Car: 1990 Camaro RS
Engine: L31
I had to slot the tang and the retracters bolted in fine but the covers will not fit now. The fourth gens sit up higher and do not allow them to sit down where they need to. Has anyone else ran into this?
Car: 1990 Camaro RS
Engine: L31
Re: 4th gen rear seat belts don't fit well
Well I have come to the conclusion that fourth gen seatbelts suck. While they physically bolt in (with mods on the rear), they do not fit well. In the front, even with 1982 sills the receivers don't naturally rest in the opening and must be bent into place. This puts tension on the door sill every time you buckle up. In the rear, you cannot put the covers back on the tensioners. They just sit up too high to allow them to fit.
My advice is to not bother with the belts.
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
It's nice that the 4th gen front seats fit well in our cars, but I'm not surprised the rear belts don't as I never thought the rear seats did either. Many people here showing how the had to modify the rear seats to make fit, and I've always thought the results look bad.
The 4th gen front seatbelts are supposedly better functioning than the thirds with only an upper retractor, so I would be willing to put more effort into them to get them to look right.
I've been curious about exactly how the floor end fits, haven't seen any pics yet.
Please post a pic of the seat belt mount at the door sill? I had heard people modified the 82 sill to work better. I'm actually starting production on door sills that will be molded with no cut out at all, so they may be a better starting point.
Car: 1990 Camaro RS
Engine: L31
No cut out at all would be perfect, you don't need one. I will get you a good picture for you to see.
Great! That would be very helpful.
When making the mold I was thinking I would make it with the retractor cutout molded in, but I decided a lot of people might want to use them for the 4th gen or race harness seatbelt conversion since the 82s are getting hard to find. I wasn't sure if there would still need to be some sort of cut out for the 4th gen floor mount.
Putting the finishing touches on the mold now, hopefully popping a test pair by next week. Mine will be epoxy fiberglass or carbon fiber, not original texture or pattern. Should be a lot better than the original junk.
Car: 1990 Camaro RS
Engine: L31
Thanks! Yes I had read the 82 cutout wasn't exactly correct. Looks like uncut would work, but maybe a half circle cut out behind the 82 hole would be best?
Car: 1990 Camaro RS
Engine: L31
I will get a better picture when I have time. An angle looking towards the outside of the car would help a lot. When you buckle up, the buckle is pulling towards the middle of the car so it would not stay in any cut out. As it is with the 82 sills, if you got into an accident you would move forward until the slack allowing them to sit in the sills is taken up. I know an accident would suck either way but I don't want a running start into my seatbelt, lol.
I think you are correct that no cut out would be the way to go then.
Does it seem like the belt would get hung up under the lower edge of the sill? Would a bevel of some kind work? Or does it stand away from the sill enough that it's not an issue?
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
In your instance, why not dremel the oval hole back farther to accomodate the sest belt guide?
Car: 1990 Camaro RS
Engine: L31
Here is an inside view:
Opening up the slot would not matter because the seat belt receiver wants to naturally sit on the inboard side. You have to force it out to go in the slot and like I said, I don't want a running start into my seat belt in the event of a collision.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
