Quick steering wheel/column removal question.
Old Mar 15, 2014 | 07:55 PM
J-money's Avatar
Car: 92 RS camaro, 99 Z-24 cavalier
Engine: 5.0L TBI, 2.4L
Im in the process of removing the steering wheel and lowering the column to change the lock cylinder and ignition switch. I rented a puller kit from Advance auto but none of those bolts with thread in the steering wheel more than 1/2 turn. My question is can anyone recommend a different puller kit to buy? Or if anyone knows the right bolt sizes. I dont really want to run all over town renting puller kits from all the different autopart stores.
Old Mar 15, 2014 | 08:11 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Quick steering wheel/column removal question.
http://www.harborfreight.com/46-piec...set-69889.html
does it look like this.
Why Rent,You should have just bought one for this price.
Old Mar 15, 2014 | 08:22 PM
J-money's Avatar
no its not anything like that one. however that one is on my to buy list from harbor frieght. the only reason I dont have that one is cuz I dont live close enough to the nearest one to make a trip down just for that.
Old Mar 15, 2014 | 08:35 PM
mantaguy's Avatar
Engine: 5.0 EFI
It's a good tool to have in your shed.
The one you rented,did it look like this
http://www.harborfreight.com/steerin...set-68982.html
Old Mar 16, 2014 | 12:45 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I have used this one before.
Amazon Amazon
The bolt size should be 5/16-18x4 1/2 inch (unless mine got mixed up. lol)
Old Mar 16, 2014 | 07:26 AM
J-money's Avatar
@manta guy, yes it was like that one but didnt have quite as many pieces.
And Scorpner thanks for the bolt size.
Old Mar 16, 2014 | 09:10 PM
J-money's Avatar
Went and rented a puller kit from autozone and had the steering wheel off in 5 minutes. For what ever reason advances didnt have the right bolts. One of the bolt holes was damaged as well, looks like someone has had the steering wheel off at some point in the past.
Old Mar 16, 2014 | 09:13 PM
Scorpner's Avatar
Engine: V6, V8
Good to hear.
Old Mar 18, 2014 | 07:41 PM
J-money's Avatar
ok guys i kinda ran into another problem with this lock. I got to the lock cylinder and unplugged it at the bottom of the dash. I then tied a piece of string around the end of it and tried to gently pull the wiring out from the top, but the connector and string broke off from the bottom. Is there an easy way to route the wiring from the lock back down to below the dash that Im just completely over looking?
I wasnt really wanting to tear the column down any further, but I dont see an easy way to route that connector all the way down there with the other wires in the way.
Old Mar 18, 2014 | 08:07 PM
mantaguy's Avatar
Engine: 5.0 EFI
Maybe this will help you out.
Old Mar 18, 2014 | 08:57 PM
J-money's Avatar
Thanks for the diagram, Im still scratching my head on how to feed that wire. I'll mess with it again tomorow maybe. I know theres got to be an easy way of doing that.
Old Mar 18, 2014 | 09:21 PM
Scorpner's Avatar
Engine: V6, V8
I can't really help much but to say to be careful not to force it too much, and that from what I recall I've had to loosen things up and/or reposition to allow the connectors to pass through. Been a while so I don't remember specifics.
Also, the parts are old, and the plastics can be brittle. Take your time.
Watch for pinched wires too.
Old Mar 19, 2014 | 12:04 PM
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
Dude, the harness goes out the bottom. The easiest way to work on the column is to pull it from the car then chuck it in a vice. As for getting the harness back in, forget the string and flip the column upside down then it falls back into place.
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
jahblah
Aug 12, 2015 05:54 PM
3rdgenparts
Aug 8, 2015 07:09 PM
