Heads Up Display?
Old Apr 13, 2014 | 01:56 PM
DirtySpleen's Avatar
Car: 1991 Camaro RS
Engine: 5.0 L03
Axle/Gears: 3.43 Torsen 10 bolt
Heads Up Display?
So before I joined the Army an bought my old 91 RS on the other side of the country, I had an 04 Corvette Z. Well I still have it, just.. on the other side of the country One of my favorite features was the Heads Up display that was pretty much a screen reflecting the RPM, Speed, and either oil, temp, fuel, or several other options of your choice onto the windshield in view of the road, so that you never had to look at the cluster for safety reasons. I'm curious how all of this could be implemented, if anyone has done it, and any ideas pertaining to this. Our dashes have such a nice flat work space to build off of, I'm just itching to see it be done!
Old Apr 13, 2014 | 02:55 PM
visitor's Avatar
Car: genesis, equus, f250, camaro, other
Engine: 5.7
Transmission: t5
Re: Heads Up Display?
Id grab a unit out of a grand prix personally
Old Apr 13, 2014 | 05:34 PM
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
I have always wondered the same thing. Would love to see one on our cars. I know theres a special windshield that HUDs use, at least on the 90s Bonnevilles that I used to own.
Old Apr 13, 2014 | 05:43 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Me too as well!, but i only see it possible with VSS optioned cars. Mine is not one of those.....
Old Apr 13, 2014 | 05:59 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I have a old thread kicking around and had all the parts from a 91 cutlass and 88-93 grand prix. But never did it because I had a 4thgen dash. It will wire in easily in flat dash cars. You will just have to see if there is enough visibility with the unit installed. It is very easy otherwise.
Old Apr 13, 2014 | 06:52 PM
Nighthawkf-117's Avatar
Car: 91' Camaro RS
Engine: 305 TBI V8
Transmission: 700/R4
Axle/Gears: Stock
The problem with a HUD is that you need special glass for it to display clearly. It is actually semi reflective. I have thought of doing the same thing and I think the best option would be to get a piece of Teleprompter glass (30% reflective) and set it up like you would find in a airplane HUD. I have also seen people that have put a small semi reflective sticker on the windshield were you want to aim the HUD.
Old Apr 13, 2014 | 07:03 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Not necessary at all. There are plenty of people swapping non HUD cars to HUD cars without changing the windsheild. I did it on my old GP and the HUD display worked fine. You would never notice unless someone told you.
Old Apr 13, 2014 | 07:35 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
I owned a 2001 GTP with a HUD. The windshield was exactly the same as a non-HUD car, except mine had a very minor tinted square where the HUD displays on the windshield. You would never notice it if you didnt know it was there.
Old Apr 14, 2014 | 12:05 AM
Car: 1991 Camaro RS
Engine: 5.0 L03
Id even be willing to cut into the dash to seat a HUD. Thats how the vettes are. Good point on the reflective part.
Old Apr 16, 2014 | 09:31 PM
Car: 1991 red Z/28
I am not sure where I'd run my wires to if I were to put an HUD into my Camaro.
Old Apr 18, 2014 | 01:14 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Easily, the HUD pigtail would go under the dashpad and into the back area behind the cluster.
Old Apr 30, 2014 | 05:07 PM
visitor's Avatar
Engine: 5.7
Transmission: t5
Mounting it would be.the.simple part. Wiring would be more confusing (imo). I have a few hud's from newer and older gp s. Id be happy to donate one to the cause if someone wanted to figure it out
Old Apr 30, 2014 | 05:08 PM
visitor's Avatar
Engine: 5.7
Transmission: t5
I know ebay has some generic ones available too.
Old Apr 30, 2014 | 11:36 PM
Car: 1991 red Z/28
I guess I should have specified about my wires. I meant what would I plug my HUD pigtail into? I know it would go under the dash pad
Old May 1, 2014 | 06:42 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
You'll need to connect +12V ignition feed, ground, tach, and your VSS. The tach wire is a white wire connected to you gauge cluster. The VSS wire varies on color and PIN number throughout the years. It can be tapped into behind the gauge cluster as well. You'll have to check the wiring diagrams for your car. If you've got an earlier cable-style speedo, you'll need some type of adapter or buffer box to create the electrical pulse signal used by the HUD.
I have one sitting in my basement from a mid-90's Pontiac something that I pulled from a junkyard. Just haven't gotten around to wiring it up.
Old May 1, 2014 | 06:12 PM
Car: 1991 red Z/28
Ok thanks. That's a big help. One of these days I'll be able to get down to a PNP in Sacramento and get one. Its hard with a family living so far away from any junk yards.
Old Apr 7, 2015 | 08:32 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I know there have been a couple of threads on this topic, and this particular one is a year old. But I thought those interested in adding a HUD unit to their car might want to see this article from a service industry publication I get. A system to keep an eye open for in the future.
Add-on heads-up display unit scheduled to enter aftermarket arena
http://www.searchautoparts.com/after...orta?cid=95879
The only thing that article does not define is if an OBDII feed is needed.
Old Apr 7, 2015 | 10:25 PM
Rabble-Rouser's Avatar
Car: 84z28, 2--1983 TA's
Engine: 305 H.O
Transmission: 700r auto
Glad to have seen this! Thanks for bringing this thread back!
Old Apr 11, 2015 | 11:56 AM
DynoDave43's Avatar
No problem. I thought it was an interesting idea.
Old Apr 11, 2015 | 07:08 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
that would be great
Old Apr 11, 2015 | 09:21 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I seem to remember someone doing a project with the GTP heads up display or something. I'm fairly sure it was on these boards, the poster had pictures of the mock-ups and how it was going to be wired into the car.
I can't find the thread, but I do remember reading about it.
Old Apr 14, 2015 | 07:58 AM
jichniow's Avatar
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
I do a little data logging to help with tuning. There's an app for Android devices called ALDLdroid. I use it so I can log the computer data with my phone instead of a laptop. It has a HUD feature, where it displays everything in reverse. You just put your phone/device up on the dash and you have an instant HUD. You need an ALDL cable to go along with this, or the bluetooth adapter, but it works. You can customize the display to show anything you want.
However, our winshields are laminated glass. There is a reflection from the surface of both pieces of glass. The end effect is multiple images. Something will have to be added to the windscreen to prevent this effect.
Old Apr 15, 2015 | 12:26 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
I tried exactly what jichniow is talking about. There are very noticeable reflected images. It looked pretty bad.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
