Saddle paint?
Old Apr 22, 2014 | 07:55 PM
karllo's Avatar
Car: 87 GTA
Engine: 350 Tpi
Transmission: 700 R4
Saddle paint?
Hi, i have a 87 trans am and i am looking for 100% paint match, got the saddle interior, someone could tell me the # of the paint or a link to direct buy the paint, did a search but the result was not concluing. Thanks!
Old Apr 22, 2014 | 08:26 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Saddle paint?
http://paintref.com/cgi-bin/colorcod...r=3972&rows=50
WA9148 is the code for Light Saddle.You could go to your local Auto Paint Supply co.and have them mix it in a spray or just have it mixed by the Pt-Qt.A few members here and I had ours mixed at a shop named BAPS in York PA.
Old Apr 23, 2014 | 07:09 AM
karllo's Avatar
Car: 87 GTA
Engine: 350 Tpi
Re: Saddle paint?
Thanks for your answer! look a litle darker than my interior...maybe mine is too much faded...it is the color for the 62 saddle for 87years?
Old Apr 23, 2014 | 07:59 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Saddle paint?
The color codes listed on paint ref are for exterior paints. No correlation to interior colors. Since gm and other manufacturers didn't paint interior, they have no records or charts for interior paint or dye. The only way to get a good match is to use a computer scanner or copy what someone else has discovered to be a good match. Some companies have gone through the matching process already for popular colors, for example SEM produces GM landau black in a can. I know many people here have been searching for a good matching tan, not sure if I have seen someone match it well yet.
Manta, have you painted your interior panels with that code? Your interior looks great.
Old Apr 23, 2014 | 12:34 PM
mantaguy's Avatar
Engine: 5.0 EFI
Re: Saddle paint?
I used the code 72I(Carmine Red)The OP has to find his interior color code 1st.I was using the GM color codes for reference.
He needs 62I,Interior Trim Lt.Saddle
Old Apr 23, 2014 | 12:37 PM
stealtht/a's Avatar
Re: Saddle paint?
Just to clarify some more manta, you got the int code for your car from the RPO or some other source? Then BAPS was able to use that code to mix your color?
Old Apr 23, 2014 | 12:39 PM
mantaguy's Avatar
Engine: 5.0 EFI
Re: Saddle paint?
I think motobooks did a nice match on his TTA,I have to check his threads.
Old Apr 23, 2014 | 12:53 PM
mantaguy's Avatar
Engine: 5.0 EFI
Re: Saddle paint?
I used my RPO Code 72I,and BAPS mixed it in a spray bomb.
Old Apr 23, 2014 | 12:54 PM
mantaguy's Avatar
Engine: 5.0 EFI
Re: Saddle paint?
Luis,(motobooks) used this,but it's Beechwood not Saddle.
Old Apr 23, 2014 | 01:12 PM
mantaguy's Avatar
Engine: 5.0 EFI
Re: Saddle paint?
This is how mine came.
Old Apr 24, 2014 | 07:30 AM
stealtht/a's Avatar
Re: Saddle paint?
Thanks for sharing! I wonder where they are looking up the paint code? Paint ref.com doesn't have any of those codes listed.
Old May 4, 2014 | 07:10 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Saddle paint?
I used SEM-15173 (camel), it looks good but it is not an exact match of the original colors https://www.thirdgen.org/forums/post...68-post13.html
This pic shows the original light saddle tan vs SEM-15173 https://www.thirdgen.org/forums/atta...0247-104ko.jpg
Here is a pic of the original beachwood tan https://www.thirdgen.org/forums/atta...0372-121ko.jpg
Would be nice if someone could find out the original tan, standard color codes.
Hotrodboba400
Dec 10, 2019 07:07 PM
MORREALE5
Sep 10, 2015 08:58 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
