A-Pillar weatherstrip?
Old Jun 23, 2014 | 07:52 PM
THCARGUY's Avatar
Car: 1985 & 1991 Trans Ams
Engine: 350 in both
Transmission: Auto in both
Axle/Gears: 3:23 Limited Slip in both
Anybody know where I can find the correct weatherstrip to replace the worn out ones on my interior A-pillar mouldings?
Old Jun 24, 2014 | 07:08 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: A-Pillar weatherstrip?
AFIK it's not available. It's not really a model specific part. It's just a flat strip of foam rubber. They didn't even glue it down much at the factory since it's not really a weather seal, just keeps stuff out of the a pillar trim when the window is down.
You can use almost any generic rubber strip there.
Old Jun 24, 2014 | 08:31 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
what stealtht/a said, take a piece to a local hardware store and match it up as close as you can, most people buy the smaller sized garage door seal, as it is angled and only has the adhesive on half of the strip
Old Jun 24, 2014 | 08:38 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Are you talking bout this?
1Aauto.com has them
Old Jun 24, 2014 | 12:50 PM
THCARGUY's Avatar
Engine: 350 in both
No, it's not the triangle rubber. Caveman305 and StealthT/A know what I'm talking about. I have some replacement a-pillar trim pieces but they all have cracked rubber. If it didn't show some when the car door is open I wouldn't fool with it. I have looked but so far could not find something similar enough to work well. I will try looking for the smaller garage door seal. That sounds like it might work. Thanx guys!
Old Jun 24, 2014 | 02:13 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
i got what your looking for...
it was hard to dig up somthing. to fill the Void. (thats all GM did) fill a Void.
after lots for digging looking and trying things this is what works the best in looks and fit.
you will have to add a STRIP of the 3M thin tap to it (see pics)
after its on it will lay just as the other stuff GM used. and fit the same.. 100%
you can get it from any NAPA parts store
after you install the A Piller plastic the fit will look just like it did from GM..
what i wanted it to do was fit 100%. i have had my car from the day it left the dealer. i i just found the cracks in the void seal they used. this is the only thing i found that will sit and stay and push out just a itty bitty bit. just as GM used.
yes it's not shaped the same...you could take the time to cut out the back so you have the V shape of the real GM stuff. but ya dont have to. all your doing is filling the Void... one bag will do both sides.
your A piller plastic will be marked as to placement. start to finnish (mine was) add just a tad bit more looks better when on..
Old Jun 24, 2014 | 03:30 PM
Caveman305's Avatar
Engine: L03, LB9
Good info artic, will definitely need it in the futur
Old Jun 24, 2014 | 07:34 PM
THCARGUY's Avatar
Engine: 350 in both
Now that's what I'm talking about. Thank you articwhiteZ!
Old Jun 25, 2014 | 07:18 AM
stealtht/a's Avatar
That's not too thick arctic Z? Doesn't hold the trim part out? Seems a lot thicker than what was there before.
Old Jun 25, 2014 | 03:38 PM
THCARGUY's Avatar
Engine: 350 in both
I've ordered a 20' roll of that weatherstrip so I'll let you know if I have the same good luck as articwhiteZ did.
Old Oct 17, 2014 | 04:51 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Ameriseal 11000 is not sold many places and you get more than you need. Once I do mine I'll probably have enough left for another card. LMK if interested in the leftover.
Old Oct 17, 2014 | 08:23 PM
92GTA's Avatar
Put me at the top of that list please, I'll take what you have left if it will do another car!
Thanks!
Old May 2, 2023 | 05:58 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Bumping this up for those not aware of it. Fixing to try it myself.
Old May 3, 2023 | 08:16 AM
topduarte's Avatar
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Thanks. I need to do this to the z28.
Old May 3, 2023 | 09:17 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
the generic under hood seal works fine as well. can be picked up at AZ or one of the others and comes with the tape strip already on.
Old May 3, 2023 | 10:50 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
T-Top A pillar cover weather stripping - Third Generation F-Body Message Boards
Old Nov 21, 2023 | 08:23 PM
cdoyle's Avatar
Where did you find the 11000?
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
