Where do the T-Tops connect in the rear?
Old Jun 28, 2014 | 08:57 PM
tkruger14616's Avatar
Car: 1990 Firebird Formula
Engine: 305 TBI
Transmission: auto
I have a 1990 T-Top Firebird. In the rear I have found and attached the the front hook for the T-Top bag. Unfortunately the rear trim panel is from a non T-Top car. There are no hooks for the T-Top bags in the rear panel. Does any one have a picture or a diagram of how the hooks are attached? I think I will need to go to a junkyard to get these but want to know what is involved.
Old Jun 29, 2014 | 12:49 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Where do the T-Tops connect in the rear?
There should be two brackets welded to the sheetmetal behind the trim panel.This is where the "hooks" would attach, so the straps can secure on.If your lucky, they might be there already & you may just need to cut the slots on the trim piece.
Old Jun 29, 2014 | 09:26 AM
Hal87's Avatar
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
My rear brackets are screwed in, easy to replace if they aren't there. The junkyard or EBay should have them.
Old Jun 29, 2014 | 02:43 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Brackets welded to the body structure.
Short bars screwed to the bracket, just like the front bars screwed through the carpet.
Rear plastic panel has a slot cut for each bar to poke through.
The hooks on the bag hook on the bars.
Old Jun 29, 2014 | 03:12 PM
Hal87's Avatar
Guess I considered the short bars the brackets. If it's a T-top, the mounting straps should be there.
Old Jun 29, 2014 | 08:07 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Back to the original problem... either find a T-Top rear trim panel, or cut slots in the panel your have.
Old Jun 29, 2014 | 08:31 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
On the back of the plastic panel should be a outline of the area to cut out for the metal straps to stick out of. IIRC.
Old Jun 29, 2014 | 08:56 PM
Engine: 305 TBI
Transmission: auto
I have the brackets welded to the back wall. Just missing the cut outs and the hooks. Found a set with the bolts on EBay. should be here in a week or so. Thanks for confirming what I was looking at.
I'llrocya
Exterior Parts for Sale
Nov 11, 2015 05:45 PM
Reddeath210
Oct 6, 2015 08:20 AM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
t-top89
Aug 21, 2015 09:52 PM
