Dash Question
Old Jul 17, 2014 | 11:53 AM
elmillgoa's Avatar
Dash Question
My dash needs to be re-done and I'm not sure what type of pattern the vinyl is for my 85. Does anyone know what pattern of grain was used.
Old Jul 17, 2014 | 03:09 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: Dash Question
Generally you can't just "redo" the dash; it's made of plastic, and once the plastic starts cracking, there's no turning back. Sure, you can fill the cracks and dye it, but they'll come back along with many others in little time.
Best bet is to get a used dash that has no cracks from the for sale forums here, or just put an aftermarket cap on yours if you're not terribly worried about fit/finish/being correct.
Old Jul 17, 2014 | 10:51 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Dash Question
Rip all of the existing material off and fill any holes or low areas with expanding foam from a can and sand it smooth. Then take it to an upholstery shop and have them recover it. That's the easiest and cheapest way to make it look good
Old Jul 17, 2014 | 11:20 PM
94ElBanditoDeCa's Avatar
Car: 88 Trans AM
Engine: 5.0 TPI
Transmission: BW T5
Re: Dash Question
I got mine from the local junk yard and it only costed me 25 bucks its like new too.
Old Jul 18, 2014 | 07:25 AM
elmillgoa's Avatar
Re: Dash Question
Guys I understand what your saying, but I still haven't gotten an answer to my actual question.
Does anyone know what style of grain is used on the vinyl or where I can find that information?
Old Jul 18, 2014 | 09:37 AM
coconut88888's Avatar
Re: Dash Question
http://www.justdashes.com
I haven't used them but when I get into my restoration I plan on it.
Old Jul 18, 2014 | 02:50 PM
elmillgoa's Avatar
Re: Dash Question
Thank you for the link. It had the information that I was looking for.
If any of you would like to know it is haircell grain.
Old Jul 18, 2014 | 10:15 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Dash Question
What do you plan to do with the info? I mean, even the places that reman these cant make them in the correct grain.
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
redmaroz
Aug 16, 2015 11:40 PM
Vintageracer
Aug 11, 2015 08:13 PM
