gas gauge help
Car: 1985 Camaro SC
Engine: 2.8L V6
gas gauge help
I need help with my Gas Gauge. The thing was working perfectly fine until I installed LED lights behind the gauges on my 1985 Camaro Sport Coupe. I spun the needle a few times on accident and removed it from the cluster a few times for ease of access. Now the gas gauge is actually empty just before half a tank and full about 1/2 a tank after "Full", in the black area. Do I just buy a new gas gauge and plug it right in or will I need to get the gauge calibrated? It doesn't matter where I set the needle to, whether the car is off or on or the gas gauge in or out. It will always start at the same spot it did before I try to reboot it. Different amounts of gas will predict where it starts ofc, as it works but starts in the wrong area.
Car: 1985 Camaro SC
Engine: 2.8L V6
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: gas gauge help
but mine is stick beyond past full!
It sounds as if there is a break in the connection somewhere; could be the PINK wire (variable voltage) from pick-up, the black wire (ground), a connecting point ( plugs/connectors ) and very possibly; the clusters printed circuit has failed. This is becoming very common problem with 25+ Y/O printed circuits. If you install the wrong replacement printed circuit ( or cluster ) there will be warning light and backlighing problems. Camaro Printed circuits / Clusters are compatible from 82-84,... then from 85-89.
Car: 1985 Camaro SC
Engine: 2.8L V6
Re: gas gauge help
If you take a perfectly good fuel gauge system and disconnect the voltage wire - or the ground wire - the gauge will shoot past full when the key is turned to RUN.
Installing a replacement gauge is a Plug-&-Play install,... no calibration needed.
Re: gas gauge help
Your problem doesn't seem like a broken connection because you get variable readings.
If the needle was spun around or removed from the gauge - I'd replace it 'just to be sure'.
I'm guessing your issue is related to the gauge itself or the sending unit in the tank. ( voltage seems too high across the whole range ) If possible I'd pull the gauge out and re-set it to BE SURE that it was properly installed on inside the cluster. I ASSUME it's possible that it could be caused by a failing printed circuit on the cluster too, but would start by getting another gauge.
( no calibration needed ! )
Car: 1983 Z28
Engine: 385 Fastburn
Re: gas gauge help
I've always heard spinning needles on gauges will mess them up, very fragile internals. I'd replace the gauge.
Car: 1989 Iroc Z28 Convertible
Engine: V8 5.0 305 TBI
Re: gas gauge help
Wow I have the same issue. I thought it was because I put a new sending unit in, but I also replaced the lights in the dash with LEDs and now it reads half when full and gets a bit more correct when I get lower. I just made it a habit of filling up often, but would love to know a fix for this. I have tried disconnecting the battery and resetting the system, still no good. Won't go above 2/3rds a tank.
Re: gas gauge help
I don't think it's the LEDs themselves, but what you did when you changed them. I put them in and have no problem with my gas gauge. I never messed with the gauge though, just the sockets in back.
Car: 1985 Camaro SC
Engine: 2.8L V6
Re: gas gauge help
Yeah it must be the gauge because everything is working and accurate in the sense that it has an empty/full but doesn't stick. It is off by like 1/4 of a tank. I spun the needle a few times mindlessly and ended up damaging the return spring in the speedometer. I had it sent out wednesday for a full rebuild. Of course, with my luck the gas gauge was messed as well after playing with the needles. Somewhat expensive lesson learned. More feedback is gladly appreciated. Where can I get a gas gauge that will actually work other than a junkyard? None of them around here have third gens.
Re: gas gauge help
You could probably have bought a whole cluster from one of our vendors for what you will pay for a speedo repair. Then have the spare cluster to spin the needles whenever the urge strikes you. Sorry had to say that IDKY.
We all have done things that in retrospect were bad ideas. If John can't help you out with a gauge check with Beths91camaro.
We all have done things that in retrospect were bad ideas. If John can't help you out with a gauge check with Beths91camaro. Thread Starter
Car: 1985 Camaro SC
Engine: 2.8L V6
Re: gas gauge help
We all have done things that in retrospect were bad ideas. If John can't help you out with a gauge check with Beths91camaro.Thread
Ghettobird52
Jul 5, 2024 11:18 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
