Leather Covered Dash
Car: 1991 Camaro Z/28 Convertible
Engine: LB9 305
Transmission: A4
Axle/Gears: Stock
I recently met the guys from NTTGA and mentioned that I had covered the dash of my vert with leather and had it double stitched like on the high end cars.
They said i should put up some pics so here they are.. Let em know what you think?
I also had the centre arm rest covered the same way
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Leather Covered Dash
Excellent work.Your stitching's nicer than mine.How's the vent/speaker are look? That's where i had the most trouble.Is the dash leather two pieces?
Did my console lid in perforated.You should to stop resting your arm on yours.Had to break that habit after i rebuilt the foam on my lid.
Engine: LB9 305
Transmission: A4
Axle/Gears: Stock
Thanks all.. it came out really well. I will admit that it is not my stitching... i have a guy!
It was one piece for fitting then folded and stitched with the excess then cut away so it was smooth.
The vent was not a problem except for the shaping around the corners but the speakers are perforated leather in 2 square panels over the speakers..the finish is nice but maybe i would do it different next time
Engine: LB9 305
Transmission: A4
Axle/Gears: Stock
As for the cost, 4 seats new foam and new leather and the dash in leather came to about $800.
This sort of work the only one on the car where being in this part of the world benefits me!
Axle/Gears: 10 Bolt 2.73 Open
Engine: LB9 305
Transmission: A4
Axle/Gears: Stock
Car: 89 Camaro RS
Engine: LT1 w/ 70mm Turbo
Transmission: Stage 3 TR6060
Axle/Gears: 4:10
Would he do another one? I would be very interested in getting mine done. For the cost of an aftermarket one, this is probably a better way to go.
