Power to Manual Windows Regulators
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Power to Manual Windows Regulators
The short answer is - No.
This picture shows the mounting holes you will need to use when re-mounting the window regulators to the doors. Obviously; this is a manual window door.
With Manual windows, The 2 FRONT rivets holding the regulator in place are located in the front mounting holes closest to the BACK of the car. (See pic)
With Power Windows , The 2 FRONT rivets holding the regulator in place are located in the front mounting holes closest to the FRONT of the car (See un-used holes in yellow circles).
The other 2 regulator mounting holes ( red circles ) will line up with the right door holes once the front 2 are in set in the right place (depending on the swap. )
The manual regulator and the power regulator are not the same shape and I don't see any way that the manual "crank" could be added to a power regulator without major work...... MUCH simpler to just get the regulators you need rather than trying to fabricate. I've got a set of manual window regulators available,... if your interested in a set just send me a PM that includes your ZIP code and I'll reply with all the details.
Car: 85 Camaro /65 Lemans
Engine: 305 vin H / 396-375 hp (Real)
Transmission: 700R4 / 4sp
Axle/Gears: 3.08 posi / 4.88 posi
thanks for this post and reply-I have an 85camaro and had to get non rusted out doors-I had a manual crank which is what I am going to use but the doors I bought and the inerds were power. I appeared that both sets of holes would line up with my manual regulator so what holes to use for manual was my question before I had them riveted.
great reply
tom
great reply
tom
