Door Panel Problems
Old Jan 15, 2015 | 03:32 PM
blktransam's Avatar
Car: 1988 and 1987 Trans Ams
Door Panel Problems
Hey Guys, I have two different styles of door panels for my '87 TA. I'm changing out doors on the TA, and the new doors have brackets for the older style door panels... Does anyone know how to change out the metal brackets on the doors? I think the newer style door panels look amazing.
Newer Style Brackets
Newer Style Panel
Older Style Brackets
Older Style Door Panel
Old Jan 15, 2015 | 03:44 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Door Panel Problems
They look like there just riveted in, drill out the rivits and do a swap.
Old Jan 15, 2015 | 03:46 PM
87350gtanj's Avatar
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
Pretty straight forward swap and those "newer" door panels are actually GTA door panels.
Old Jan 16, 2015 | 10:10 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Originally Posted by mantaguy
..........drill out the rivits and do a swap.
Make sure that you swap the interior door handle/lever too. The GTA handle has a hole for a mounting screw - others do not.
Old Jan 19, 2015 | 06:35 PM
blktransam's Avatar
Glad you told me that
Old Jan 19, 2015 | 06:37 PM
blktransam's Avatar
Really? I don't think my car is a GTA? They are sweet looking, whatever they are!
Old Jan 19, 2015 | 06:38 PM
blktransam's Avatar
How do you put new rivets in? (after you drill them out)
Old Jan 19, 2015 | 09:17 PM
mantaguy's Avatar
Engine: 5.0 EFI
Pickup a nice inexpensive rivet gun,they work great,very easy to use.
http://www.harborfreight.com/heavy-d...tle-66422.html
Old Jan 20, 2015 | 12:54 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
you will use blind rivets (aka pop-rivets)..
Lon
Old Jan 20, 2015 | 03:18 PM
blktransam's Avatar
Great, thanks for the help guys!
Old Feb 4, 2015 | 04:01 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
IIRC, these door panels were standard on GTA, and available on other models as a "custom interior" or "deluxe interior" option. See this thread for more info https://www.thirdgen.org/forums/inte...ml#post5606690
Old Feb 5, 2015 | 02:18 PM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Axle/Gears: 3.23 - Posi -10 Bolt
Yep, my 87 Trans Am non-GTA had the deluxe door panels.
Old Feb 8, 2015 | 02:04 AM
TRANSSPORT's Avatar
Car: 1991 Firebird SS group A
Engine: 305 TBI
Transmission: 4L60
Axle/Gears: PosiTrac / 273
Late in the model run Pontiac changed the bezel to a tear drop design. This is true of all late gen 3 firebirds, not just GTA's. As pointed out, you will need the door handle shown in the photo (this one is broke, the mounting hole bracket is what you need to pay attention to). You will also need the teardrop shaped bezel trim unless you plan to cut those panels up to try and run the old, square bezels. I have a pair of black deluxe armrests for sale if anyone needs them.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
