Removal of shift knob
Old Feb 8, 2015 | 04:33 PM
Al_z28's Avatar
Removal of shift ****
I have a 1983 Camaro and in trying to replace my cracked auto shift ****. It's the round ball with the button on top. It doesn't twist or anything and it doesn't have the clip behind it either, how can you remove these *****?
Old Feb 8, 2015 | 09:56 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Removal of shift ****
Move the shifter all the way to the rear of the car. Look down at the base of the shift **** from the front of the **** and you'll see the small slot. Inside is the clip you'll remove with a small flat-blade screwdriver.
Lon
Old Feb 9, 2015 | 11:19 AM
Al_z28's Avatar
Like I said it doesn't have a clip or anything, it's just the ball and the button
Old Feb 9, 2015 | 11:24 AM
Joe Tag's Avatar
83 ball ***** have a snap ring under the button inside the ball. 87? up have the staple type Lon is referring to.
Old Feb 9, 2015 | 11:26 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
pull the button off, look inside and you'll see a snap ring. remove the ring and it'll pull right off, I too have an automatic '83
Old Feb 9, 2015 | 09:48 PM
Al_z28's Avatar
Thank you!!! Do you guys know any other way to remove the clip without the snap ring pliers?
Old Feb 9, 2015 | 11:04 PM
sorrys70's Avatar
needle nose pliers and 2 hours of misery
Old Feb 10, 2015 | 06:46 AM
Car: 1983 Z28
Idk about 2 hours, but some needle nose pliers and a bit of patience will do it.
Old Feb 10, 2015 | 08:40 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
I used ice picks until I bought a set of snap ring pliers.
Old Feb 10, 2015 | 08:47 AM
Joe Tag's Avatar
It's not like it's a big investment. Buy the tool and have it forever. http://www.harborfreight.com/snap-ri...eads-3316.html
That being said, I have used pointy needle nose and picks with success, but the right tool works so much better.
Old Feb 10, 2015 | 04:14 PM
my82roc's Avatar
Car: 89 Iroc Convertible
I use a thin flat blade screwdriver to remove the snap ring.Sometimes it takes a few tries but it's an aquired technique
1992 Trans Am
May 10, 2023 07:19 PM
3rdgenparts
Exterior Parts for Sale
26
Apr 7, 2016 11:21 AM
dhonda200
Aug 11, 2015 11:50 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
