Computer orientation...
Old Mar 28, 2015 | 07:07 PM
Smokinbrd's Avatar
Hey guys and gals, I have an 86 T/A and the interior was mostly disassembled when I purchased it. I would like to know on the passenger side under the dash how and where the computer mounts, this one is dangling with plastic bracket on it.... Thanks.
Old Mar 28, 2015 | 09:09 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Computer orientation...
The bracket has a point on it,look up under the dash(right hand corner just behind the pouch),you will see that there is a hole in the dash that the point on the bracket slides into,then use two screws to hold it up there
Old Mar 28, 2015 | 09:13 PM
Smokinbrd's Avatar
Thank you very much!
Old Mar 28, 2015 | 09:20 PM
mantaguy's Avatar
Engine: 5.0 EFI
Take your time.
Old Mar 28, 2015 | 09:30 PM
Smokinbrd's Avatar
I will for sure, have been looking and looking for a pic just showing it in there from any angle for a visual, nothing.... Lol
Old Mar 29, 2015 | 02:37 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
It will appear similar to the attached.
Old Mar 29, 2015 | 09:04 AM
Smokinbrd's Avatar
Nice! I wonder if it would be best to disassemble the dash or doable without doing so? Looks like that tab comes off of speaker mount assembly.
Old Mar 29, 2015 | 12:06 PM
mantaguy's Avatar
Engine: 5.0 EFI
No you don't need to take the dash apart,just use a flashlight to find the hole,it's simple.
Old Mar 30, 2015 | 08:41 AM
Wife'sCar's Avatar
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
Had to zip tie mine up, it was just laying on floor and didn't know about the screws, I thought some tabs had broke off or something.
Old Mar 30, 2015 | 09:10 AM
Smokinbrd's Avatar
Yes, as you look up, the bracket lines up with 2 white plastic inserts where you line up on outside and fasten. If you haven't messed with this before it all kinda blends in... Lol
Old Mar 30, 2015 | 09:58 AM
Wife'sCar's Avatar
Engine: 5.0 Tbi
Oh well, it's good and secured now!
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
1nastygta
Sep 24, 2015 08:58 AM
