Removing dashpad, what to expect?
Old Dec 18, 2015 | 11:24 AM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
I'm removing the dash pad in order to resolve a terrible squeaking in the middle of the dash. The pad is remarkably easy to take off and it has been off recently at a shop. My question is what will most likely require replacing in the dash? One side is loose, but placing a towel there doesn't help it, so I imagine it is a dash internal
Old Dec 18, 2015 | 12:39 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Removing dashpad, what to expect?
Missing support screw?
Old Dec 18, 2015 | 11:44 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Check for loose screw too.
Old Dec 19, 2015 | 01:36 AM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
You are referencing the exterior screws, correct? If so, they're all there. The far right has a screw that is stripped and so it acts as if no screw is there, I plan on replacing the threads
Old Dec 19, 2015 | 02:37 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
When you take the dash off, look on the underside to see if there are any rub or"wear" marks. If so, apply some felt.
Then, put you hand in the dash and see if anything feels "loose".
If not, keep the pad off, drive the car with a buddy and see if touching parts of the dash makes the noise disappear...it will be trial and error.
Old Dec 19, 2015 | 11:06 AM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
word of advice, when you take the bolts out near the windshield defroster make sure you put a rag over or tape it off first. I was extra careful when taking them out but still managed to drop one in there
89irocz355
Oct 8, 2023 12:59 PM
85RS
Jan 7, 2016 04:01 PM
84z28355t5WC
Dec 24, 2015 12:30 AM
ZsTransAm
Dec 22, 2015 10:06 PM
johnbhm
Brakes
Dec 15, 2015 08:15 PM
