full interior with roll bar
Old Jan 3, 2016 | 03:49 PM
bk92rs's Avatar
my autocross, track car and daily driver. roll bar install, sub frame connectors
Attached Thumbnails full interior with roll bar-87-iroc-1.jpg   full interior with roll bar-87-iroc-2.jpg   full interior with roll bar-87-iroc-9.jpg   full interior with roll bar-87-iroc-12.jpg   full interior with roll bar-87-iroc-15.jpg
full interior with roll bar-87-iroc-16.jpg   full interior with roll bar-87-iroc-17.jpg   full interior with roll bar-87-iroc-25.jpg
Old Jan 3, 2016 | 06:46 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: full interior with roll bar
That's cool! Where did you mount the rear bars? Any diagonals or would that kill the use of the rear seats?
Old Jan 3, 2016 | 07:12 PM
bk92rs's Avatar
rear seat is usable, i dont normally have more than one person that rides with me, my other car is a corvette, bars go all the way to the back.
Attached Thumbnails full interior with roll bar-87iroc5.jpg   full interior with roll bar-87-iroc7.jpg
Old Jan 3, 2016 | 10:48 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
The door bar is too low to pass tech on an IHRA or NHRA track.
It has to run between your shoulder and elbow
Old Jan 4, 2016 | 11:20 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Running the door bar that way is really common outside of drag racing orgs. A lot of drift guys do that.
Old Jan 4, 2016 | 11:44 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Door bar that low is it really even worth while to put it in? Seems like it doesnt do much
Old Jan 4, 2016 | 09:24 PM
bk92rs's Avatar
I understand it wont pass nhra or ihra, its also not fast enough to require one. Autocross doesnt require one, neither does track days. The car being my daily driver I chose to have full interior, so i went with a low bar. As far as the door bar serving an help, the you ever felt a t top car twist in turns? Sfc helps as do tubular control arms and pan hard bar, the roll bar helps also.I believe its as good as a full frame car now. Plus im having a blast with this car
Old Jan 5, 2016 | 12:24 AM
Night rider327's Avatar
Car: 1988 Camaro
Keep in mind the backwards way NHRA works... It don't matter if you are fast enough to need it or not.. If it's there, it counts.
Like if you have a roll cage (has the roof halo bars and A pillar bars), you must have a window net just to get through tech... Be it in an 8 sec or 18 sec car... Does not matter.
If you have roll bar, you must have padding
If you have roll bar or cage, to race it on an NHRA track the door bar must be between your elbow and shoulder.
Mine is a street car too and for years was my daily driver.. I used a swing out door bar kit for mine, which is legal down to 8.99 in 1/4 mile IIRC
Old Jan 5, 2016 | 10:18 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
If you can weld, it wouldn't be much trouble to install a swing out bar to replace the one you have. Also, nice to see someone else using a t grip shifter handle!
B4C5.7
Exterior Parts for Sale
25
Feb 3, 2016 07:32 AM
B4C5.7
22
Jan 24, 2016 11:40 AM
terrorsquad77
Jan 12, 2016 11:15 AM
Redsome
Jan 5, 2016 09:51 PM
podiatra
Dec 31, 2015 05:17 PM
