82 shifter knob conversion
Old Mar 15, 2016 | 09:02 AM
arkyknight's Avatar
82 shifter **** conversion
I have the T style shifter in my bird right now and I want to install my 82 knight rider style shifter. Would it be hard to convert/install or can it only be done with one of these aluminum billet reproduction shifter kits to retrofit it?
Old Mar 15, 2016 | 02:15 PM
dcd2236's Avatar
Car: 1987 trans am, 1988 Formula
Engine: 305 LG4, 305 LB9 TPI
Transmission: 700R4 in both
Re: 82 shifter **** conversion
Do you have the 83-84 t-style or the 85-92 t style?
Old Mar 15, 2016 | 08:51 PM
arkyknight's Avatar
85-92 style
Old Mar 15, 2016 | 09:41 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Since your profile is incomplete I have no idea what year you're working on, but here is the info you're looking for.
The only thing that holds the shift **** on is either a c-clip under the round button (82-84), or a u-clip on the front of the shift **** (85-92).
You might be able to use your existing shift assembly or you might have to swap some of the parts from an older unit. The issue is that even though all of the parts from 82-92 are pretty much interchangeable, if your car is '85+ and has an overdrive trans I believe the shifter will be different.
Old Mar 15, 2016 | 09:45 PM
dcd2236's Avatar
If you want to use an original **** the easiest way is to find a camaro shifter between 83-86 which are referred to as the eight ball shifters. The **** will slide on with very little modification to it. The billet ***** use set screws and a drill bit to get the **** to sit at the right height to work. I had an original **** so I went option one.
Old Mar 15, 2016 | 11:26 PM
arkyknight's Avatar
Sorry about that, I am working with a 91 with an overdrive transmission. Thank you for your help guys.
Old Mar 16, 2016 | 11:44 AM
dcd2236's Avatar
Here is what you need for the use of an original ****
http://www.ebay.com/itm/1985-Camaro-...RWxrUr&vxp=mtr.
The modifications you will have to do are as follows.
When you install the **** you'll notice that one of the notches will have to be modified in order to get the **** to sit past the groove for the c-clip, easy fix with a dremel tool. When you go to put the button on the stem you'll notice it will stick up higher than it should. This is a trial and error part but be careful not to cut off too much or the button will be to far down to work. Don't be afraid to take it back off and reinstall it as many times as it takes to get it right. Once its getting close then sandpaper will work to make finer adjustments to the stem for the button to sit just right.. You want the button to sit just above the edge of the **** like its peeking over the top of it.
To see what im talking about use this link and scroll down to the interior picture and save it to your computer and zoom in. Its the best example I could find.
http://oldcarmemories.com/1982-ponti...namic-warrior/
Old Mar 18, 2016 | 09:04 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Pretty sure the auto shifter itself from 82-83 was different from all others ?
Aren't those early years the type with a removable plastic rod - with a bunch of round studs along it's length - thru the middle of the shifter ? Didn't the 84+ have a permanent piece of flat plastic in the center of the shifter arm ??
Old Mar 18, 2016 | 11:46 AM
arkyknight's Avatar
I appreciate your help guys thank you, I need to think on this one which route I'm going to take. I'm doing this on a budget so I'm caught between buying the $100 aluminum shifter with the retrofit kit or just buying this $50 piece you've pointed out on ebay given I've got the mechanical know-how to do so.
Old Mar 18, 2016 | 09:04 PM
my82roc's Avatar
Car: 89 Iroc Convertible
I got a Camaro shifter assembly from an 83 and the 82 firebird knight rider shift **** fits on it perfectly with no modification
1Aauto
Sponsored Vendors
Apr 12, 2016 01:48 PM
PurelyPMD
Exterior Parts Wanted
Mar 21, 2016 08:37 PM
BlackMamba94
Mar 16, 2016 11:39 AM
AmpleUnicorn88
Brakes
Mar 15, 2016 07:04 AM
1988_f-bird
Mar 15, 2016 01:06 AM
