seat lock !
Old Apr 9, 2016 | 02:37 PM
senior bear's Avatar
seat lock !
HI ALL im new hear.have just purchased a 88 firebird .sumthing that puzzles me.the front seats tip forward for access to rear seats.should the seats lock in the upright position.seats adjust but will flop forward with no lock to use previos owner said thay been like this all time he has owned the car .thanks for any hellp steve.
Old Apr 9, 2016 | 02:54 PM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
Re: seat lock !
I have the same problem, something with the mechanism inside. Remove the plastic cover
and see if anything is bent or broken. I know somewhere in the forum there is a article
what to look for.
Old Apr 9, 2016 | 03:01 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: seat lock !
They Use An Inertia Type Front Seat Back Lock System.
Old Apr 9, 2016 | 03:09 PM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
Re: seat lock !
If you googleInertia Type Front Seat Back Lock System there is a PDF download,
got to fix mine someday.
Old Apr 9, 2016 | 04:12 PM
Re: seat lock !
Thanks ill look that up
Old Apr 11, 2016 | 02:14 AM
Drew's Avatar
Re: seat lock !
The stock seats don't lock unless the car is parked on an incline, in which case you have to use the lever on the seat back to fold the seat forward.
Old Apr 11, 2016 | 12:42 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: seat lock !
Correct, why would there be a release lever on the seatback if they're not on permanent lock! It's the shoulder belt that inertia locks, not the seatback.
Try a little spray lube on that lever, it may not be fully seated, allowing the seatback to pivot forward.Think that happened with mine once.
Old Apr 11, 2016 | 12:50 PM
BOTTLEDZ28's Avatar
Transmission: A4
Re: seat lock !
Stock seats do NOT lock in place. I thought I had the same problem until a dozen members here confirmed that their seats all do the same thing. The 4th gen car lock i believe but not ours. Drew explained it perfectly a few post ago.
Old Apr 11, 2016 | 01:38 PM
someone972's Avatar
Car: 1991 Firebird Formula
Engine: 5.7L TPI
Re: seat lock !
I'm really confused now, because I have one seat that locks all the time and one that does not lock. I thought it was just a common issue with these cars that it doesn't lock? Seems like it should lock all the time like my passenger seat.
Old Apr 11, 2016 | 01:54 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: seat lock !
Would it be normal if your unoccupied pass seatback tilted forward whenever you slow down or brake.Inertia lock only activates under sudden stop/extreme hard braking.The rest of the time the seat back is free to flop about, doesn't sound right to me.
If a dozen members said they have the same condition with their seatback/s.Then dozen more members have non functional seat locks.
The release lever is described in the owners or service manual.I've seen in there somewhere.It isn't just forth gens.
Old Apr 11, 2016 | 04:08 PM
gt4373's Avatar
Re: seat lock !
It's The Seat Back Not The Belt.
Old Apr 11, 2016 | 05:53 PM
Black_TA's Avatar
Car: 1983 Trans Am
Axle/Gears: Stock
Re: seat lock !
Strange I thought mine locked, was ready to take them apart. I know there is a black
lever in the center. I will have to park on a hill and check it out.
Old Apr 11, 2016 | 09:27 PM
Drew's Avatar
Re: seat lock !
There are so many things you learn when you read the owners manual.
Old Apr 11, 2016 | 11:01 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: seat lock !
I gotta find my service manual, I swear I read something about that lever in there.
Old Apr 11, 2016 | 11:41 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: seat lock !
It is a common problem, but If the seat-back lever has to be used every time you try to push the seat back forward then it "should" be fixed. ( had something to do with occupant safety ?!? )
If you grab a seat hinge and hold it firmly so it doesn't open/close, then shake the entire assembly,.......... You can hear the inertia lever rattle around inside the hinge.
I always hated it when I had a Seat that wouldn't just push forward after opening the door, I realize the release lever is 'right there',...but it still bothered me every time I did it. ( until I replaced the seat hinge !! )
Old Apr 11, 2016 | 11:44 PM
someone972's Avatar
Engine: 5.7L TPI
Re: seat lock !
Haha, guess the one I thought was broken is working and the one I thought was working is broken.
Old Apr 12, 2016 | 12:05 AM
John in RI's Avatar
Re: seat lock !
Just gotta' go with your gut on those 50 - 50 gambles !!! I know that feeling, kinda' like suddenly realizing that you've been singing a song with the wrong lyrics - for a couple years !!
Old Apr 12, 2016 | 10:23 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: seat lock !
By seat hinge do you mean the recline mechanism deal on the side of the seat?
Old Apr 12, 2016 | 11:29 AM
John in RI's Avatar
Re: seat lock !
Yup, that's the one.
Old Apr 12, 2016 | 12:48 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: seat lock !
From the Owners Manual!!
I always thought they were not working also!!
Old Apr 12, 2016 | 08:50 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: seat lock !
I can tell you from experience that in an accident they will lock and not go forward.
Old Apr 17, 2016 | 02:50 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: seat lock !
A trick to help keep the passenger seat from flopping forward under braking is to tilt the seat back towards the rear a couple of notches. It lowers the center of gravity so the inertia has less effective on the seat back.
Old Jan 21, 2018 | 10:58 PM
SirReveller's Avatar
Car: '89 'ROC
Engine: 5.7L
Re: seat lock !
This almost deserves a sticky. I bet a ton of guys were vaguely thinking their seats were busted! I sure was. ..The levers on basically every other 2dr car I've ever been in always had to be used to unlock the seat for back passenger entry/exit. Well, great to know. One less thing.
Old Jun 8, 2019 | 03:55 PM
YoungPittsburg's Avatar
Car: 1989 Iroc Z convertible
Engine: 5.0 TPI
Re: seat lock !
Yeah thanks for this! Thought I had a busted seat!
ThirdGen1984
Exterior Parts for Sale
May 6, 2016 07:46 PM
chuck13
Interior Parts Wanted
Apr 6, 2016 06:53 PM
esc
Apr 4, 2016 01:27 PM
kitt23
Apr 3, 2016 01:08 PM
Dletts
Mar 26, 2016 10:56 PM
